I have currently bought all of my parts for my pc, shown below. This is my first time building a pc, so are there any tips you can give specific to the parts I have bought or just in general? I have done a lot of research, but if you think anything might be helpful please share. Thank you!
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor  ($385.00)
CPU Cooler: Corsair - H100i v2 70.7 CFM Liquid CPU Cooler  (Purchased For $85.00)
Thermal Compound: Thermal Grizzly - Kryonaut 1g 1g Thermal Paste  (Purchased For $13.00)
Thermal Compound: Thermal Grizzly - Conductonaut 1g Thermal Paste  (Purchased For $13.00)
Motherboard: Gigabyte - Z370 AORUS Gaming 5 (rev. 1.0) ATX LGA1151 Motherboard  (Purchased For $136.00)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3200 Memory  (Purchased For $146.00)
Storage: Samsung - 850 EVO-Series 250GB 2.5" Solid State Drive  ($75.00)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($59.99 @ Amazon)
Video Card: Zotac - GeForce GTX 1080 8GB AMP! Edition Video Card  (Purchased For $445.00)
Case: NZXT - S340 Elite (Black) ATX Mid Tower Case  ($79.99 @ SuperBiiz)
Power Supply: EVGA - SuperNOVA G3 650W 80+ Gold Certified Fully-Modular ATX Power Supply  (Purchased For $64.99)
Operating System: Microsoft - Windows 10 Pro OEM 64-bit  ($30.00)
Monitor: Acer - XB241H bmipr 24.0" 1920x1080 180Hz Monitor  (Purchased For $240.00)
Total: $1762.97
https://linustechtips.com/topic/868836-tips-for-building-pc/
2 minutes ago, Valkyrie Lenneth said:
general tip, put a dvd disc or somthing over ur psu grill so that u dont drop a screw inside xD if u have the grill up
Thanks for the advice! I think the s340 elite has a psu filter on the bottom so I'll face the grill towards the floor, but I can imagine how annoying it must be to drop a screw inside your psu!
https://linustechtips.com/topic/868836-tips-for-building-pc/#findComment-10780728
trust me it happens even to the best xD lol keep that grill away from screws
https://linustechtips.com/topic/868836-tips-for-building-pc/#findComment-10780730
do cable management last, because otherwise you might put cables in the way of other hardware.
unplug your mechanical hdd when installing Windows, so you don't get confused which drive is the ssd at the install screen. it's really annoying if you accidentally install it to your hdd.
when you plug your hdd back in, and boot to Windows, the hdd won't be displayed, because it isn't formatted yet. (believe me, i thought my first brand-new drive was broken when i first plugged it in)
not to mention dangerous!
She/Her
Phone: OnePlus Nord CE 5G | 128GB | 8GB Ram
Main Desktop: Ryzen 5 3600 | GTX 1060 6GB | 32GB Ram
Main Laptop: Acer Aspire V3-771G | Core i7 3612QM | 16GB
https://linustechtips.com/topic/868836-tips-for-building-pc/#findComment-10780734
  • Don't rush anything, take your time. You're not building systems for a living.
  • If it doesn't fit, it doesn't fit. Don't force it.
  • Cable manage as you go, don't leave it until the end.
  • Find a safe place to put all the screws so you don't lose any.
  • Read the manual if you get stuck, or for those stupid front connector pins.
  • Buy a case of beer.
Honestly, it's super easy and really shouldn't take any longer than half an hour, if not less.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/868836-tips-for-building-pc/#findComment-10780738
I'm kinda concerned about cable management and just figuring out which cables go where. Is it obvious once I start?
https://linustechtips.com/topic/868836-tips-for-building-pc/#findComment-10780745
yea it's pretty obvious.Just the put the thing with the other coresponding thing
Also if you don't have one already it'll make your life a lot easier if you have a magnetic screwdriver
My life
https://linustechtips.com/topic/868836-tips-for-building-pc/#findComment-10780751
  • Honestly, it's super easy and really shouldn't take any longer than half an hour, if not less.
these two i disagree with.
1. at the end is usually better. if you are inexperienced, it's easy to tie down cables that block slots that you need if you cable manage as you go.
2. nope. especially with a lot of components. it usually takes me 30 mins just to mount a hyper 212 to a socket.
She/Her
https://linustechtips.com/topic/868836-tips-for-building-pc/#findComment-10780753
yes, it's pretty obvious. if you want to be sure, use the manuals provided with the power supply and your components, to be sure what to connect to what.
She/Her
https://linustechtips.com/topic/868836-tips-for-building-pc/#findComment-10780755
Yeah. Reference point #2 :P
You have a modular PSU so you have an even easier time of it, you only have to install the cables that you need. I would have gotten an m.2 drive so you could save yourself some cabling, but what's done is done.
Basically there's the 8 pin for the GPU, the 24 pin for the CPU, and I think another for the motherboard. When you look at the sockets the side with the plastic lip is the one that the clip goes on.
Yeah, there's many ways to do it, and every person is different. I find it way easier to do it as I go, but I can also visualize where the components are going. As for taking 30 minutes to mount a cooler, no offense, but that's absurd. I mean sure, it can take that long, but it shouldn't. You'd be fired within your first 2 hours of working at a computer shop as a builder :P Granted some people just don't have the mind for assembling things.
https://linustechtips.com/topic/868836-tips-for-building-pc/#findComment-10780761
well, i'm very careful. i've broken some mobo's in the past with hastely mounting coolers.
and yea, i'm sure i'll get quicker at it if i do it more, but i don't assemble custom coolers that often. i've only done it like 4 - 5 times.. i usually use stock coolers.
She/Her
https://linustechtips.com/topic/868836-tips-for-building-pc/#findComment-10780769
Another question, is it risky to build a pc if there is a carpet on the floor? I've heard about anti static wristbands and the dangers of shorting out your components, but does it matter that much?
https://linustechtips.com/topic/868836-tips-for-building-pc/#findComment-10784841
Too many variables to answer that reasonably. Just build it in the kitchen.
https://linustechtips.com/topic/868836-tips-for-building-pc/#findComment-10785092
