Hi guys
I ran a system stability test on aida64 yesterday but got hardware failure but when i dont select system memory it goes perfectly fine.
What is the problem and do i have to change my ram? ( please no if i dont have to)
anyone help pls. I think this is why my games are crashing.
Msi GTX 1060 Gaming X 6G - AMD Ryzen 5 1600 - MSI B350 Tomahawk - Corsair Vengeance LPX 8GB 2400MHZ - CoolerMaster Masterwatt Lite 600W 80+
https://linustechtips.com/topic/868717-aida64-system-memory-failure/
1 minute ago, Talha Akbayrak said:
Hi guys
Run Windows Memory Diagnostic or MemTest86 to be sure it's a memory issue.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
I completed the test and got no error. So i believe its because of software or settings?
Just now, Talha Akbayrak said:
I completed the test no error. So i believe its because of software or settings?
What are the rest of your specs including motherboard and PSU?
Msi gtx 1060 6g gaming x
msi b350 tomahawk
amd ryzen 5 1600
corsair vengeance lpx 8 gb 2400 mhz
coolermaster masterwatt lite 600w 80+
msi b350 tomahawk
amd ryzen 5 1600
ryzen mem issue, my mate also got it u need to overvolt ur ram for stability / mem controller
thats also a problem for me because when i change any setting in bios it doesnt boot..
yeah mate has it too, its the dreaded ryzen ram bug
what u cna do is loosen secondary timings to gain stability
And people still wonder why I've already chose my next build to be Intel based rather than AMD. Ryzen seems like a pain in the ass to work with. Probably the first modern platform I've heard that throws a hissy fit at almost anything.
Can u tell me what exactly your mate did to solve this problem ? Because im so f**king done with this error.
This was my first build so i cant really say anything lol
But u better do so if u dont want to encounter any problem like this shit
truth is, all amd products are a pain to work with to get stable :v
it depends per rig but there are some secondary timings that u can loosen up to be able to boot with different settings, i forgot the exact name id have to reboot for that xD, its similar to refresh rate but then with somthing else ( its not refresh rate however )  numbers go in like 250-500ish :v
Alright thanks anyways now imma go sleep, tomorrow i will want help from amd support ( if anyone cant help me here) .
I mean my current 890FX build has been pretty solid for the past 6 years. Of course there has been issues but most seem to just be Windows being Windows.
Apart from the entire thing just failing when it tried to solve a 5000x5000 matrix on MATLAB. Never stress tested the overclock long enough for that sort of workload.
to me i run prime95 atleast 24hours on both filling the ram and small fft to ensure a chip is stable, i dont trust anything else anymore bcoz i once ignored prime and crash in the end anyway
amd support wont be able to help u really, i doubt they even know how to set timings , just loosen up ur secondary timings
Actually i cant really sleep now since im so obsessed with this thing. Imma try it now.
I ran it for that 30 minutes and deemed it good "enough". And it was fine for anything I threw at it (even video rending)... until MATLAB came along. :P
dude i ran my stress tests 24hours everytime and after 15hour/17hours somtimes i get a bsod or error
"Do as I say, not as I do" - Linus Sebastian.
i think everyone who avoids prime95 to say, it stresses to much dont know what their doing xD p95 only does calculations, if it cant succeed then chip aint stable, linus also went to aida64... i once tried aida and all i got was UNSTABLE OC'S   tried every stress tool possible other than p95, p95 crashed, rest didnt > boom still bsod after a hour or two xD
