When you mean upgrade you mean the specs right?
Fill us in on the deets,bro
??? Wanna join ??? my free??gift card??? giveaway??? Click ⤵ the subrscribe button?? ,turn? the notifications on ??? and finally leave a nice comment ??down below⬇⬇ , now without further adue ??? lets get on?? with the video▶▶
https://linustechtips.com/topic/868598-setup-help/#findComment-10778524
well i upgraded the specs last year i got my 1060 but still got a i7 2600 but im fine with that im talking about the setup itself the desk headphones monitor or basically anything that you think can help my setup or make it look better.
https://linustechtips.com/topic/868598-setup-help/#findComment-10778543
New monitor if the budget allows, maybe some LED light strips behind the desk. Move that coaster off to one of the back sides of the desk, it seems kind of awkward sitting out there in the middle. The cables coming out of the PC could really use some sleeving or tubing so that you just see one large black cable rather than all those cables tied together.
https://linustechtips.com/topic/868598-setup-help/#findComment-10778548
Just now, Septimus said:
I would also recomend moving the monitor back a little, almost so that it's under the shelf.
i can get some led strips and i planned 100% already on getting a cable sleeve for the cables I already zipptied 90% of cables under my desk and sorry about the coaster dont like my desk getting dirty ill move it but the monitor is very small tbh i can see that well if its that far because its only 21.5 inch i can move it back a bit but not that far.
https://linustechtips.com/topic/868598-setup-help/#findComment-10778560
Here's a video that you can use to make some judgement on performance by Gamer's Nexus
And Kyle has one using the 6700k instead of the 7th gen
https://linustechtips.com/topic/868598-setup-help/#findComment-10778562
As for items around/on the desk, I see you have some figurines above the mouse pad. Move those either up on the shelf with the PC, or somewhere else on the desk. Have you seen the things like fake potted plants and salt lamps? Those make a pretty nice addition to any setup.
https://linustechtips.com/topic/868598-setup-help/#findComment-10778564
Yeah, small monitors are a struggle xD
https://linustechtips.com/topic/868598-setup-help/#findComment-10778567
I have a salt lamp litterly 5 minutes ago broke the blub gotta go get a new one.
https://linustechtips.com/topic/868598-setup-help/#findComment-10778569
i was going to move the poster and get some acoustic foam panels to help sound to not leak outta my room would that look good?
https://linustechtips.com/topic/868598-setup-help/#findComment-10778573
As long as you can adjust it after you place it on the wall,in case you make a mistake. But it shouldn't be a deal-breaker
https://linustechtips.com/topic/868598-setup-help/#findComment-10778579
Yeah, those posters seem rather close to the shelf from the perspective of the picture - I'd agree with your decision to move them a bit. Honestly, I would spend money on lighting long before I would spend money on foam panels. When you're buying foam panels, you probably have top of the line audio gear and you do professional work like podcasts (I am assuming you don't). I would instead save money to buy things like a new monitor and some nice lighting. Maybe consider a ceiling light fixture that projects light onto the poster, and some LEDs for behind the desk as mentioned earlier. Foam panels are one of the last things I would go for.
https://linustechtips.com/topic/868598-setup-help/#findComment-10778593
1080p 144hz monitors aren't too expensive, most are around $300 so that can help in the future If you plan to play at higher refresh rates.
1440p 144 hz on the otherhand is like $500 at the minimum Last time I checked.
https://linustechtips.com/topic/868598-setup-help/#findComment-10778610
well i got a xlr microphone and do some recording here and there but no streaming i was just gunna get them becasue sound leaks from my rooms easy so i really want to reduce that but yes i planned to get a monitor some light strips and cables sleeves and if possable some plants i guess
https://linustechtips.com/topic/868598-setup-help/#findComment-10778614
i was gunna get 144hz on cyber monday but i frogot to buy it and now the cheapest one is like 180 and only 22inches.
https://linustechtips.com/topic/868598-setup-help/#findComment-10778618
FeelsBadMan
If you're upgrading from 21.5, I'd say 27" is your best bet because after that it's usually ultrawides and those are hard on your Grapics card. Especially for 1060
https://linustechtips.com/topic/868598-setup-help/#findComment-10778623
1 minute ago, PerfectPlasma said:
FeelsBadMan
see im like no money rn i got like 120$ for a new monitor max if u can find me a 27 inch i can but rn 24 is my max budget.
https://linustechtips.com/topic/868598-setup-help/#findComment-10778629
did moving my stuff around help or naw
https://linustechtips.com/topic/868598-setup-help/#findComment-10778634
Well i took some advice from what you guys told me and i moved some stuff around is this better? also were should my salt rock go
You could move those strips on the case onto the back of the monitor to make "mood lights" if you're not buying any more. They help when you game at night by keeping the brightness of the background about the same as the monitor so when you look away for a second your eyes spend less time on brightness and that helps with eye strain.
https://linustechtips.com/topic/868598-setup-help/#findComment-10778636
You could move those strips on the case onto the back of the monitor to make "mood lights" if you're not buying any more. They help when you game at night by keeping the brightens of the background about the same as the monitor so when you look away for a second your eyes spend less time on brightness and that helps with eye strain.
alrighty give me a min ill do it
https://linustechtips.com/topic/868598-setup-help/#findComment-10778640
alright set it behind my monitor to white is that good? or should it be another color
https://linustechtips.com/topic/868598-setup-help/#findComment-10778690
yo were should my salt rock go you think?
https://linustechtips.com/topic/868598-setup-help/#findComment-10778696
That should be good. When night comes around try adjusting the brightness and color to see what feels the best for your eyes.
Linus has a FaP on it,as well.
https://linustechtips.com/topic/868598-setup-help/#findComment-10778701
