Inactive Monitor Dims
Well, I just tried closing DisplayFusion, and that seems to be the culprit. According to several threads I saw on different sites, that's supposed to be an optional feature that requires a plugin.
Thanks for trying to lend a hand, but it looks like I'll just have to spend an hour or so in the millions of different settings for DisplayFusion. I'll update this thread when I find exactly which setting it is so anyone who might end up in my shoes can save some time.
EDIT: It looks like "Monitor Fading" got enabled. The default hotkey is CTRL + ALT + F. If that doesn't solve it, open the settings, click the "Functions" tab, then scroll down and find "Toggle Monitor Fading." This will show you the current hotkey, and if there isn't one set, you can change it to whatever you'd like.
