I need a block for a Gigabyte GeForce GTX 1080 Ti GAMING OC 11GB Graphic Cards N108TGAMINGOC-11GD and i found the  Phanteks PH-GB1080TiGB_BK01 Glacier G1080Ti Gigabyte but its out of stock everywhere and am not sure if they discontinued it or not. I already looked at EKWB but all the have is the universal block. Help!!
https://linustechtips.com/topic/868275-help-finding-a-part/
Buy EK's universal block if that's what's available. It should work just fine.
@michelin_boi=much moto, very wow
need best cpu cooling? add 2 stroke oil (but no, really don't)
5 things newegg doesn't want you to know:
  1. wait
  2. for
  3. black
  4. friday
  5. sales
https://linustechtips.com/topic/868275-help-finding-a-part/#findComment-10775717
4 hours ago, Uribe408 said:
i have and theres nothing
Contact Phanteks to see if they are still producing the block and a reseller, if they aren't your probably going to need to source old new stock or a used block. EKWB has no plans on making one for this card.
https://www.ekwb.com/configurator/step1_complist?gpu_gpus=3791
https://linustechtips.com/topic/868275-help-finding-a-part/#findComment-10776675
