So Im planning on building a ThreadRipper build soon:
TR 1920x
Aorus X399 Gaming 7
GTX 1080 AORUS Rev 2.0/Vega 64 (if it ever becomes available for a lower price in the near future.)
4x4GB Dominator Platinum 3000mhz
3x 7200rpm HDD's
3x SSD's
My main Work on this will be Game Development, Gaming, Video Editing and some 3D rendering.
Questions:
1: Can I temporarily use this build on a Corsair VS650 as this PSU has only one 8pin cpu connector?
2: How Does Ryzen perform on Unreal Engine 4?
3: How Does Ryzen/Vega vs Ryzen/1080 perform on Blender?
4: How Does Ryzen perform on Substance Painter/Designer?
5: How Does Ryzen perform on Visual Studio 15?
6: Are 2x8 pin CPU connecters absolutely  required?
Also Suggest a good compact ATX case for my build.
PS. Id prefer if you have first hand experience of Ryzen/TR/Vega.
https://linustechtips.com/topic/868137-threadripper-build-questions/
No, because the moment you'll launch application that puts more than 30% on the GPU and CPU it will explode
What kind of cooler are you gonna use? I'd recommend at least the Liqtech 240
Don't buy Apple M1 computers with 8GB of RAM
Havnt decided on one, although im leaning toward the Noctua coolers as they perform really well and are cheap, Although ill probably paint the outer rings of the fans
you can get the chromax fans and cooler covers
