Hello everybody,
I recently upgraded my gtx 960 to a gtx 1080 ti and i got the feeling my cpu is bottlenecking quite alot so I changed my i5 4670k @4,5 ghz to an i7 4770k @4,3 ghz.
Well i play on a 1080p 144hz freesync (AOC 2770g4) and i dont see alot of perfomance boost to the previous build.
At games like Overwatch it barely touches 100% on the cpu and gpu (fraps min 90 max 139 avg 113,1). settings at Epic.
i really dont know what it could be i reinstalled nvidia driver 388.43 and it didn´t helped
thank you in advance
Tiago
Specs
i7 4770k 4,3ghz
Gigabyte H97-D3H-CF
EVGA 1080ti SC Black Edition
EVGA SUPERNOVA 750W G2
16 GB Corsair Lpx
Deepcool Captain 240 ex
850 EVO 500GB
Seagate 3TB
WD 1 TB
Win 10
https://linustechtips.com/topic/868106-low-fps/
At 1080p, you'll still be bottlenecking the GPU according to
Daily Driver:
CPU - Dual X5670 | GPU - GTX 750 Ti | CASE - HP DL380 G7 | RAM - 128GB Samsung 1366 DDR3 ECC | STORAGE - 8 x 146GB 15K RPM HDD
Work Horse:
CPU - Quad E7-4870 | GPU - Quad Tesla M2090 | CASE - HPDL580 G7 | RAM - 128GB Samsung 1366 DDR3 ECC | STORAGE - 2 x 256GB Samsung 950 EVO SSD
https://linustechtips.com/topic/868106-low-fps/#findComment-10774235
yes but not to this degree i think look at this video of hardware unboxed
it compares high end i7 to mine it only has 20-50 fps diffrences and at overwatch 1080 ti
Average: 237 FPS (4.22 ms) 1% Low: 153 FPS (6.55 ms) 0.1% Low: 124 FPS (8.04 ms)
it´s quite more than just 20-50 fps :(
https://linustechtips.com/topic/868106-low-fps/#findComment-10774267
From the second video:
Daily Driver:
Work Horse:
https://linustechtips.com/topic/868106-low-fps/#findComment-10774282
Since I have i7 4770k and GTX 1080ti... I can assure you that i7 4770k with a bit of OC is more than capable of handling this card with no bottlenecks. I have no problem with playing at 165Hz.
Have you uninstalled your old drivers with DDU and then installed new ones?
https://linustechtips.com/topic/868106-low-fps/#findComment-10774293
not with ddu but with cclean i try with ddu
at which overclock are you at?
https://linustechtips.com/topic/868106-low-fps/#findComment-10774301
  • 2 weeks later...
