Hello every one,
I have a problem with my windows 10 when i try to power off the system it seems to be powered off.
But when i power it back on my apps that where open before are still running.
so google chrome is running when i have my pc on and when i shutdown my pc and start it the next day back on it open chrome on the site i was browsing.
And this is for every app i had running.
I tried to shut it down via CMD and that seemd to work but i dont want to open cm dand type shutdown every time and I dont need a messy backgroud with shutdown shortcuts.
Any one know how to fix this iff so please send me things to try out.
(when i shut it down with the power op button in windows i can see on a software on my phone that the pc still takes 5 or 6 watts fro the wall)
Thanks,
Danny
https://linustechtips.com/topic/868076-shutdown-problem/
On 12/3/2017 at 3:40 AM, gabrielcarvfer said:
Did you check "Control Panel -> All Control Panel Items -> Power Options -> Choose what the power buttons do" ? They're usually set to sleep, and if you don't wake up your PC, it hibernates (dump memory to disk and shut down).
I looked at those settings and the only thing I changed my self is that my monitors shutdown when i press the power button. But thats not the way i shut my pc down I do i by software.
https://linustechtips.com/topic/868076-shutdown-problem/#findComment-10782956
  • 2 weeks later...
