Dirt Bike Question
Just bought a Honda 125cc big wheel and I have never ridden a bike before.  One question; lets say I'm in fifth gear and I slow down to turn-down I need to shift down when slow down, or can I just accelerate when I'm done turning and not shift at all?  I have a Honda Rancher and I would just leave it in one gear the entire time.
https://linustechtips.com/topic/867869-dirt-bike-question/
You don't NEED to shift down, but if you don't your acceleration will be sluggish and slow, and if you're really slow in a really high gear you can stall.
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/867869-dirt-bike-question/#findComment-10772437
