Will it work?
Go to solution Solved by stealth80,
1 minute ago, Gamelord238 said:
So I will get lower speed than others users on my MB?
no, z170 is PCIE 3.0x 4, the Z97 was PCIE 2.0 x4, you are good to go
Hello,
I want to buy a new ssd for my pc, because I have pretty damn slow ssd right now and I want better. So I´m looking for Samsung SSD 960 EVO (M.2) and my question is about, if I fix that SSD into my MB-ASUS ROG MAXIMUS VIII HERO ALPHA - Intel Z170 without any problem.
Thank you for your answers
Regards
Andy.
https://linustechtips.com/topic/867846-will-it-work/
10 minutes ago, HZapperz said:
I may be wrong but it looks like you dont have an m.2 on your board, you could always go with a 800 series ssd from samsung and just connect that through a sata slot.
id be surprised if it doesn't, I'm saying this before I research it for fact. I mean I would genuinely be surprised if a RoG board based on Z170 didn't have it
update
yes it does
https://www.asus.com/uk/Motherboards/MAXIMUS-VIII-HERO/
Gen 3.0 x4
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/867846-will-it-work/#findComment-10772223
update
yes it does
Gen 3.0 x4
But I have Hero Alpha, they may have different slots?
https://www.asus.com/Motherboards/ROG-MAXIMUS-VIII-HERO-ALPHA/
https://linustechtips.com/topic/867846-will-it-work/#findComment-10772233
16 minutes ago, Gamelord238 said:
I just find this : 1 x M.2 Socket 3 for M Key, type 2242,2260,2280,2210 storage devices support (Supports both SATA & PCIE 3.0 mode) , but still i dont know compatibility with that ssd.
basically a board is made to support the varying m.2 SSD's some have more pins than others or are shorter/longer, youre good to go, the ranger 7 even supported m.2 (albeit at lower speeds due to lack of PCIE lanes)
Ryzen Ram Guide
https://linustechtips.com/topic/867846-will-it-work/#findComment-10772285
https://linustechtips.com/topic/867846-will-it-work/#findComment-10772304
Ryzen Ram Guide
https://linustechtips.com/topic/867846-will-it-work/#findComment-10772311
