Hello
I have recently purchased the gtx 1080 ti Palit Super Jetsream and i am loving it. But i was just playing battlegrounds when i noticed that my GPU usage was only 35% max. I thought maybe my CPU was bottlenecking it but that was sat at 50% usage max too. So i was a bit confused. I tried changing the FPS target to max to see if it would push my GPU to 100% but it stayed the same. I was wondering what is going on with this?
Im currently running my games at 1080p and i know that my GPU can do so much better than so im getting a 1440p 165hz moniter this christmas. If i crank up the resolution will my GPU usage increase to maintain a steady FPS counter?
PC Specs:
Cpu - i7 4790 4 Core 3.60ghz
Ram - 1x8gb kingston fury 1600Mhz
Motherboard - Gigabyte GA-B85M-D3H
Gpu - Gtx 1080Ti Palit Super Jetstream
Psu - Corsair 850i Platinum+
HDD - 2Tb Seagate Green 7200RPM
SSD - 120Gb Kingston
PC Specs:
Cpu - i7 8700k (1.25V 4.9Ghz)
Ram - 2x8Gb Crucial Ballistics 2666mhz
Motherboard - Asus Prime Z370-A
https://linustechtips.com/topic/867845-low-gpu-usage/
Just now, HZapperz said:
could potentially be the fact that you only have 1 stick of ram which i assume to be DDR3.
Yes it is ddr3, Also forgot to mention that i am getting an extra stick of 8Gb soon too :)
Its been a long awaited upgrade for my PC
PC Specs:
https://linustechtips.com/topic/867845-low-gpu-usage/#findComment-10772152
PUBG has CPU bottlenecking issues in many areas, particularly the starting zone and a few larger towns. There isn't much you can do to alleviate the issue. You might as well run the game at higher settings and wait for Bluehole to optimize the game further.
Gaming Rig
CPU: Intel i7-6850k @ 4.2GHz
GPU: 2x FE GTX 1080Ti
Memory: 16GB PNY Anarchy DDR4 3200MHz
Motherboard: ASRock X99 Extreme 4
Encoding Rig
CPU: Ryzen 7 1700 @ 3.7GHz
GPU: GTX 1050
Memory: 8GB Curcial Ballistix DDR4 2133MHz
Motherboard: Gigabyte AB350M-DS3H
https://linustechtips.com/topic/867845-low-gpu-usage/#findComment-10772156
Im sure that once you get that extra stick of ram, the gpu usage will go up and you will see a significant fps boost.
https://linustechtips.com/topic/867845-low-gpu-usage/#findComment-10772157
The next update is supposed to optimise the game a bit more but we have all heard that before. Will have to see.
PC Specs:
https://linustechtips.com/topic/867845-low-gpu-usage/#findComment-10772165
They're constantly optimizing it. There's this one optimization guide on youtube that gave me a 50% fps boost. I'll try and see if i cant find it again.
https://linustechtips.com/topic/867845-low-gpu-usage/#findComment-10772178
I tried the PTS earlier and saw a decent boost. I don't have exact numbers but it certainly felt smoother. However, there were still areas where my GPU usages was dropping due to optimization issues. The next patch is certainly a step in the right direction, but it's still not perfect. IIRC, the PTS is still up and testing the next patch, but this was a couple days ago and I'm not sure if the PTS is still going.
Gaming Rig
Encoding Rig
GPU: GTX 1050
https://linustechtips.com/topic/867845-low-gpu-usage/#findComment-10772203
