Elgato HD60 Pro
Tarheel
Hello, I was wondering if anyone could help me figure out if the Elgato HD60 Pro would or does work on the AMD Phenom II X6 1075t? I would be using it as the streaming pc until i can afford to upgrade it and I would be gaming on a different pc.
Capture card will do the rendering work. It would work with weaker laptop, so you will be fine. Just make sure you have upload speed needed for streaming.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Yea my internet handles my streaming now fine (355Mb/ps down/25Mb/ps up) just fyi id be the internal card.
