My pc keeps crashing once per day and what i mean by that is that the screen freeze i cant alt+tab+del i cant open task manager cursor not moving its a complete freeze so i need to button reset it.I dont know what the cause might be.Today i search on internet about pc keeps freezing/crashing and a random website suggested i open (view reliability monitor) and check there for any kind of errors and so i found in all dates the same critical error:
critical events :
TriggerModeMonitor : Stopped working
Windows : Windows was not properly shut dont (i know that cause i need to button reset cause its frozen)
I also found some warings about (Failed Windows Update)
I am trying to figure out what is this critical error and the warnings if any of you can help or have some ideas of what might be,be sure to write so.Thanks
https://linustechtips.com/topic/866907-help/
