Budget & Location
Budget: KWD 85 (USD 280 approx.)
Aim
1. Editing on DaVinci Resolve - editing videos shot on 4k from a mobile to be uploaded on YouTube
2. Gaming (COD4, Fortnite, GTA 5) - limited though
Monitors
Hooked up to TV (tight budget and space)
OS
Windows 8.1 - had purchased a key long back for a laptop that has since died
The story
I have taken apart a few PCs but never assembled one.
After selling off some of my electronics I have raised USD 280. I know that is not much, but a friend gifted me the CPU (i7 7700) and I had bought a GTX 960 for cheap that was being used with my laptop through an eGPU setup.
I have shopped the following parts:
CPU: i7 7700 (Free)
GPU: GTX 960 (Already owned)
SSD: Kingston 120GB (Already owned)
HDD: 500GB slim drive (Salvaged from old laptop)
Additional storage: Have an existing 1TB NAS
Mobo: Asus Prime H270M Plus (USD 111)
RAM: 8GB Curcial Ballistix (USD 99.5)
PSU: Corsair VS550 (USD 60)
Cooler: Stock intel (USD 11.5)
I landed the above within the budget. You will note that there is no PC Case - and that is because I opined that skipping out on the case helped me get more RAM. And in the mean while I can just wall mount the whole thing. An I have a power switch that I salvaged from a PC that one of my neighbours threw away.
There are two concerns though that I have:
1. The stock cooler: Though the CPU is the non-K version, I have concerns on how loud this might be. I wanted to get a low profile Cryorig - but that is not available locally. Not sure on how a tower cooler would impact the  mobo when wall mounted.
2. PSU: This was the last item I bought with what ever was left in budget. Ideally would have liked a CX430 - but that is also not available locally. The cheapest Bronze PSU would cost me twice as much.
Why am I here
Would like some guidance on wall mounting and building
This is my first build and I am sure to make some noob mistakes. I have already done a Linus with the CPU - dropping it while taking it out of the envelope it came in.
Comments on my planned upgrade in the future (after I sell some more electronics as they become obsolete):
1. Bronze PSU
2. PC Case
3. Additional 8GB RAM
4. GTX 1060 6GB (the holy grail for my given budget)
https://linustechtips.com/topic/866717-my-first-build/
buy a lower end mobo, if your buying a non overclockable chipset dont splurge for your budget. I would say an 500watt corsair or seasonic supply would be good and please get a case. Also make sure to get either a hyper 212 evo or t4 which ever is cheaper at the time.
https://linustechtips.com/topic/866717-my-first-build/#findComment-10761029
I know its fairly vauge but seasonic is a very reliable brand above around 450 watts same goes for corsair. you need a goodcooler to keep the life of that 7700 going for some time. buy the cheapest case if you want to save money and please buy a b250m or b150m motherboard with good enough vrms for editing. Im using a 6600 and a b150m mobo, i edit and do other heavy work on it with astock cooler and its quite loud, also it gets hot on a stock cooler.
https://linustechtips.com/topic/866717-my-first-build/#findComment-10761035
The lowest mobo available is an B250 and that is USD20 cheaper - would go for that if the coolers I want were available
Buying a case - I have very limited space. The cases that would fit would be like the Fractal 202 - but those are premium cases. There is no space for a mid tower in my house.
Thanks for the heads up on the hyper 212 evo and t4
https://linustechtips.com/topic/866717-my-first-build/#findComment-10761038
