PC gets stuck randomly (need help )
5 minutes ago, Smokie said:how to reset CMOS? some videos on youtube say to remove the jumper from the motherboard for a few seconds then to put it back onto the pins and some say to remove the cell battery and put it back after a few seconds ( my motherboard doesn't have any jumper) , No I don't have a back up image and I don't know how to make one though all the necessary files I've are backed up on One drive and Google drive and I already have a Windows setup on my USB stick created through Windows media creation tool
Btw I am buying 1x8 Corsair vengeance ddr4 2400mhz for my new setup would you suggest I buy another stick to make it 16gb? or should I wait for ram prices to decrease cause a few months ago it was 75$ here then it became 88$ now its 108$ heard ram prices increased internationally and will drop some where in 2018
is it true that sometimes if you do a GAP between ram sticks by GAP I mean use computer with one ram stick then buy another ram stick after a few months there are chances that they will not run together like the PC won't boot even if they're identical sticks ??? though there been cases where people used different brand ram sticks with different bus speed and the higher bus speed ram stick automatically decreased its speed to run with the slower ram stick
Though the above shouldn't be an issue for me cause I am buying the ram directly from the Corsair distributor franchise by visiting their store I could take my new build there and if the new PC doesn't boots up with identical sticks they could replace there ASAP
Rest CMOS by turning off PC, push the PSU switch to OFF, press the start button to discharge capacitors, open PC and remove BIOS battery(CMOS), leave it for a few seconds, replace battery, shut PC, turn on at PSU switch, press start button... that should have reset CMOS and set BIOS to defaults.
Windows, just refresh or re-install with USB, your choice.
Just buy 16GB now if you can afford it, might be a while before RAM prices come down again... but again your choice, you can risk 8GB being enough to get by with for now. Sticks of ram are better for compatability to be bought together in a kit, but that doesn't meant that 2 un-identical sticks can't work, it just might take more effort and/or you might not get the rated speed.
