So i have rx460 4gb and theres a new driver but when i install win shows blue screen and stop code: tread in device driver.
All.started whit just cause 3 it told.me that game is blocked by my gpu.
So i tryed to roll back to previos driver dont remeber nuber but 17/9/2or something and that update to 17/11/1 it worked (my current driver) but when i try to upgrade to 17/11/2 it gose to blue screen.
Any help?
  • CPU
    Ryzen 5 1600 af 3.2 ghz
    Cooler AMD Wraith Prism rgb
  • Motherboard
    Asrock b450m-hdv r4.0
  • RAM
    16gb g.Skill 2666MHz
  • GPU
    Inoo3d 1650 super twin x2 oc
  • Case
    Genesis titan 750
  • Storage
    Kingston a400 240gb(system)
    Seagate barracuda 2tb 7200rpm(storage)
    Samsung 1tb 7200rpm(backup)
  • PSU
    Fsp si series 700w 50arn 88% efficiency
  • Display(s)
    Dell ultra sharp 24" 1080p
  • Cooling
    X4 Led case fans
  • Keyboard
    Redragon k552-rgb
  • Mouse
    Trust rgb gaming mouse
  • Sound
    Steelseries artic 1
  • Operating System
    Windows 10 home
https://linustechtips.com/topic/866557-radeon-new-driver-need-help/
1 hour ago, emosun said:
system restore to a time when it was working
But it works fine just cant install 17/11/2.
Even jc3 started to work after restart, no errors.
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
    Genesis titan 750
  • Storage
  • PSU
  • Display(s)
  • Cooling
    X4 Led case fans
  • Keyboard
    Redragon k552-rgb
  • Mouse
  • Sound
    Steelseries artic 1
  • Operating System
    Windows 10 home
2 minutes ago, emosun said:
If it works fine then why are you trying to update a driver that has no issues. driver revisions are done to fix issues. You have no issues , so why are you updating it.
Amd drivers adds support for.more games like this one i.cant install is for bf 2 .
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
    Genesis titan 750
  • Storage
  • PSU
  • Display(s)
  • Cooling
    X4 Led case fans
  • Keyboard
    Redragon k552-rgb
  • Mouse
  • Sound
    Steelseries artic 1
  • Operating System
    Windows 10 home
8 hours ago, emosun said:
so battle front 2 doesnt install at all?
AHH(FACEPALM) i dont think u even understand.
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
    Genesis titan 750
  • Storage
  • PSU
  • Display(s)
  • Cooling
    X4 Led case fans
  • Keyboard
    Redragon k552-rgb
  • Mouse
  • Sound
    Steelseries artic 1
  • Operating System
    Windows 10 home
Battlefront 2 and Just Cause 3 should work perfectly fine on AMD drivers from 17.7.1 and up. I know because I played them. A driver update is only for bug fixes and if you're lucky a small performance improvement. A game would not disallow you from playing just because a new driver was released. Maybe if a driver or hardware was too old to support specific features, but not specifically for a newly released driver update when previous drivers worked on that game before.
17.11.2 has problems. I too experienced blue screens on my own RX 460 4gb. You could try to DDU in safe mode (Google is your friend) and install the new driver again on its own. Do not go from one version to an update in this case. Download and install 17.11.2 ONLY. If that doesn't work, stick to 17.11.1.
Whatever your problem is there's another issue going on here and it's not your driver version.
The RX series is not playing nicely with new drivers. I have read too many cases of THREAD_STUCK_IN_DEVICE_DRIVER BSoDs, and I am (or used to be at least) a victim as well, unfortunately.
I used DDU several times to try to fix the issue but never helped.
The only solution I found was a Windows reinstallation (even though it happened once since I did, but before it was happening daily).
I can’t believe that there are so many faulty cards out there that cause this BSoD. I’m fairly positive that the issue lies on the software side of things. Stick with 17.7.1, it’s the most stable latest driver.
CPU: Ryzen 7 9800X3D Cooler: Noctua NH-D15 Black Mobo: Gigabyte X870E Aorus Pro GPU: Sapphire Nitro+ 9070 XT RAM: G.Skill 2x16GB @ 6400 MHz SSD: PNY XLR8 2TB PSU: Corsair RM1000x Case: Fractal Design North Monitor 1: Asus XG27AQWMG(280Hz) Monitor 2: Asus VG259QM (240Hz)
I usually edit my posts immediately after posting them, as I don't check for typos before pressing the shiny SUBMIT button.
Unraid Server
CPU: Ryzen 5 7600 Cooler: Noctua NH-U12S Mobo: Asus B650E-i RAM: Kingston Server Premier ECC 2x32GB (DDR5) SSD: Samsung 980 2x1TB HDD: Toshiba MG09 1x18TB; Toshiba MG08 2x16TB HDD Controller: LSI 9207-8i PSUCorsair SF750 Case: Node 304
My RX 460 is successfully running 17.11.2 without issue. However I didnt bother with installing Radeon Crimson Software on my last attempt. I just let the extraction process run and manually installed the driver alone through Device Manager.
Could be Crimson Software itself? I'm running the new driver with the old Crimson binaries and it's been fine for me so far. No improvements in performance or stability and I dont play any of the games the bug fixes claim to resolve, so not much point to it honestly.
I understand where OP is coming from though. Always nice to stay up to date. Crimson actually recommends the stable driver is 17.11.1. can't argue as I'm not having difficulties, like I said, but can't really say I agree. 17.7 was solid
