Hi guys and gals,
I'm a first time builder and spent some time creating a build on pcpartpicker.com which I plan on buying. Now before I buy I would like to have it reviewed by experienced builders to see if and where I went wrong. If you are a good samaritan who is willing to extend a helping hand, please take a look at the build and check for possible errors (being something being too expensive or unnecessary, or incompatibility, or maybe choosing a different component because some other reason, etc.). Now I must add that I might buy a better graphics card in the future (not sure which one) and I'm not sure what to do with the power supply.
https://pcpartpicker.com/list/wwNh4C
Thank you in advance!
Ken
https://linustechtips.com/topic/865969-first-time-builder-needs-help/
Assuming this is for gaming and general purpose computing. I agree with thom on the SSD. Also, put some crazy filters on your case intakes because tobacco smoke will destroy your electronics. Also ruins resale value and in some cases, your warranty.
Switch out the CPU cooler for a 212 EVO or something with front to back cooling. That one is great for cooling VRMs or for a low-profile config but you're not going to need either of those.
25 minutes ago, Jaxzzzzz said:
You should try to make it more balenced, go for an i5 and upgrade to a 1060 6gb or 1070
also try to get a PSU thats a bit better than that
It for gaming and streaming the gameplay, you think a i5 would still do?
Use the stock cooler, it's fine for ~3,8 GHz. For $50 more, you could get the 1070 Ti, for ~25% better performance. Or for $90 more, you could get the 1700, for better streaming.
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($189.89 @ OutletPC)
Motherboard: Asus - PRIME B350-PLUS ATX AM4 Motherboard  ($59.99 @ Newegg)
Memory: Team - Vulcan 16GB (2 x 8GB) DDR4-3000 Memory  ($139.99 @ Newegg)
Storage: SK hynix - SL308 250GB 2.5" Solid State Drive  ($78.89 @ OutletPC)
Storage: *Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($41.89 @ SuperBiiz)
Video Card: Zotac - GeForce GTX 1070 8GB Mini Video Card  ($409.89 @ Amazon)
Case: Thermaltake - Core G21 Tempered Glass Edition ATX Mid Tower Case  ($39.99 @ Newegg)
Power Supply: Corsair - CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($34.99 @ Newegg)
Total: $995.52
Generated by PCPartPicker 2017-11-27 14:45 EST-0500
8 minutes ago, Jaxzzzzz said:
it seems like ur going for that 1000 dollar price range
heres a build that I came up with
https://pcpartpicker.com/list/4cbPM8
Thank you! But I would like to stick to Intel and I think 430 for a graphics card is a little too much for now
