On 11/27/2017 at 11:08 PM, thom derksen said:
1. There is no significant difference between SATA and SATA m.2 other than the form factor and the price.
2. I5 processors have a much better value for some use cases.
3. Make sure you don't regret the case. I got a cheapo crappy case, and regretted it 1 day later. Spend 30 bucks more and you got yourself an amazing case with great quality!
1
for
1. I prefer m.2 to sata, easier installation
3. I agree on that
32 minutes ago, m4n14c said:
What is the current status?
I'm on a '2.0' build (https://pcpartpicker.com/list/pDHhRG), but this one isn't quite there yet.
I'm swapping out the cpu fan (for now looks like CRYORIG H5 Universal) and I'm looking for a better PSU
Edited by Ken_
You are a lot over $1000, is this in the budget?  Did you check the site for the OS?
I prefer the Corsair 270R or 200R over the Deepcool case, I think are better quality, make a plan how are you going to place the parts before you chose a case.
