Good evening.
Please, I need your help.
In a motherboard I have, in an AMD AM2+ socket, I want to replace retention bracket. But I also want the sending to have also screws.
Is the following ok?
https://www.ebay.co.uk/itm/CPU-Cooler-Retention-Mount-Bracket-Kit-W-4-Screws-Socket-AMD-AM2-AM3-Motherboard/112467675355?hash=item1a2f9888db:g:CkkAAOSwLcNZWp8A
a. In the description, saying "W/4", it means screws are included? Have I understood right?
b. Also, in the description, it says only for AM2 motherboard. An down the page, it says "compatibility AM2 motherboard". I have read that. But, I am asking you if for AM2 is ok for AM2+ too?
Sorry for my questions, but not an expert.
Thank you for your time!
https://linustechtips.com/topic/865965-retention-bracket-replacement/
