Starting a few days ago in low demanding games like csgo i have seen gpu utilization dropping from 20-30% to single digits causing massive frame stutters. I have already uninstalled and reinstalled cs, reinstalled drivers, and verified game cache.
Asrock B450m/ac| Ryzen 5 3600x | EVGA GTX 1070 SC ACX3.0| 16 GB DDR4 3200 | Antec 550w SemiModular| 1 TB WD Black | 1TB SP NVME m.2 | 1TB WD BLUE SSD
https://linustechtips.com/topic/865569-gpu-usage-low/
Woah! Deja vu! I've seen this topic multiple times before.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/865569-gpu-usage-low/#findComment-10750310
you've got a pretty bad cpu tbh, 90% of the time when GPU usage is low it means your CPU can't keep up.
Main Rig
CPU: Ryzen 2700X
Cooler: Corsair H150i PRO RGB 360mm Liquid Cooler
Motherboard: ASUS Crosshair VII Hero
RAM: 16GB (2x8) Trident Z RGB 3200MHZ
SSD: Samsung 960 EVO NVME SSD 1TB, Intel 1TB NVME
Graphics Card: Asus ROG Strix GTX 1080Ti OC
Case: Phanteks Evolv X
Power Supply: Corsair HX1000i Platinum-Rated
Radiator Fans: 3x Corsair ML120
Case Fans: 4x be quiet! Silent Wings 3
https://linustechtips.com/topic/865569-gpu-usage-low/#findComment-10750391
Ok i know my cpu is a boyyleneck, but this started a few days ago, i have perfectly fone frames until now. My cpu in cs doesnt get above 90 percent
https://linustechtips.com/topic/865569-gpu-usage-low/#findComment-10750397
