you just need a regular phillips head screwdriver for 100% of the build. and all the ESD protection stuff is completely unnecessary and overkill. save yourself the cash (like 80$ total?)
get a 7200 RPM harddrive instead of this 5400 one (much faster same price no sound difference)
that's a pretty poor powersupply there's a teir list here on the forums that is very well made. get something higher up on that list.
for the cooler i'd recommend a drak rock pro from be quiet not a pure rock it's much better and will be much quieter
and maybe a be quiet case if you really want silence rather than this phanteks one but really it won't make that big of a difference
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
    MSI B350M mortar arctic
  • RAM
    32GB Corsair RGB 3600MT/s CAS18
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
    WD black NVMe SSD 500GB & 1TB samsung Sata ssd & x 1TB WD blue & x 3TB Seagate
  • PSU
    corsair RM750X white
  • Display(s)
    1440p 21:9 100Hz
https://linustechtips.com/topic/865141-need-help-good-pc/#findComment-10746580
PSU should be much better than this
Tier 2 or above for a build at this level
5400rpm HDD will be quite slow even as bulk storage.
stock cooler is quiet enough. If you think it's loud then some undervolting will do. If you still want an aftermarket cooler than get larger ones like the R1, NH-D15 or Dark Rock Pro 3
Anti-static stuff.... Let's say I cared about it a lot when I first started building PCs, but then completely ignore it. Just keeping my hands dry and clean is good enough.
Desktop benching:
https://linustechtips.com/topic/865141-need-help-good-pc/#findComment-10746585
? hello
I am now looking at this https://www.inet.se/produkt/6902298/bitfenix-whisper-m-550w whisper 550 w. Is it good?
https://linustechtips.com/topic/865141-need-help-good-pc/#findComment-10747916
Updated list
https://linustechtips.com/topic/865141-need-help-good-pc/#findComment-10747935
15 minutes ago, RobinNord said:
? hello
Yes.
Terrible experience with Seagate drives in my past.
Desktop benching:
https://linustechtips.com/topic/865141-need-help-good-pc/#findComment-10747942
16 minutes ago, RobinNord said:
Any other brand of driver recomended for same price¿?
Nearly all but Seagate. WD, Toshiba and Hitachi for example.
Desktop benching:
https://linustechtips.com/topic/865141-need-help-good-pc/#findComment-10748097
2 minutes ago, RobinNord said:
So now! Is it worth swapping 1TB for 7200 rpm?
If that's enough. In most places though 2TB ones only cost 25% more than a 1TB
Desktop benching:
https://linustechtips.com/topic/865141-need-help-good-pc/#findComment-10748148
41 minutes ago, RobinNord said:
What do you think of the rest of the cart? Good? Quiet? No bottlenecking? Right tools?
Yep seems nice
Desktop benching:
https://linustechtips.com/topic/865141-need-help-good-pc/#findComment-10748211
what do you thins of the psu? is it just a small bit better, bad or really nice? would you recomen it? saw it on top of the list...
If it's top of the list, it is v.good
Desktop benching:
https://linustechtips.com/topic/865141-need-help-good-pc/#findComment-10748250
