I built a new system a few days ago and im getting non stop blue screens... ive tried memtest for 12 hours with no errors, i also  tried a few other things butg kothing is helping?
all hardware is brand new and ive tried windows installs with a tried and tested usb install and a newly downloaded version.
Ive attached my dump files if anyone can get any info from them,
Thanks
  • OS - Windows10 64Bit
  • Age of system (hardware) - Brand new
  • CPU model - 8600k
  • Video Card model - GTX 1070
  • MotherBoard - Asus prime z370-a
  • Power Supply - corsair rm550x
  • Desktop
112517-5546-01.dmp
112517-5781-01.dmp
112517-6578-01.dmp
112517-6703-01.dmp
112517-7390-01.dmp
https://linustechtips.com/topic/865129-bsod-driver-problems/
Update or reinstall NVidia drivers.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/865129-bsod-driver-problems/#findComment-10746344
get ddu to remove nvidia drivers (if you haven't already) and the weird one that got me was a driver/firmware update for my samsung 950 nvme ssd, caused crashing and couldn't figure out why for a while, never would've thought of a storage complication... so think of odd things like that
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/865129-bsod-driver-problems/#findComment-10746363
I just got a BSOD in safe mode
https://linustechtips.com/topic/865129-bsod-driver-problems/#findComment-10746462
disconnect anything that doesn't need to be connected, less things to go wrong, then try again
desktop
HTPC
https://linustechtips.com/topic/865129-bsod-driver-problems/#findComment-10746474
I ran driver verifier and it pointed towards a sys file that was connected to intel extreme tuning utility so I just uninstalled that and I’ll see how I go
https://linustechtips.com/topic/865129-bsod-driver-problems/#findComment-10746530
6 minutes ago, ELLISRKE said:
like what?
gpu, any usb stuff other than mouse and keyboardOnce you get through the graphics driver removal and checking for unusual hardware issues you can reinstall gpu and stuff and hopefully not have these issues
desktop
HTPC
https://linustechtips.com/topic/865129-bsod-driver-problems/#findComment-10746653
i took stuff out and still getting the same errors...
I did the test thing it says in the post instructions? is this any help for you?
https://drive.google.com/open?id=1i3G89DUXMrFCwh5UvxM5eqVjJsBrmkjk
https://linustechtips.com/topic/865129-bsod-driver-problems/#findComment-10746945
