VOID Pro Charging time
Go to solution Solved by Badger906,
charge time is worked out by battery capacity divided by charger output. mAh/mA= charge time.
a standard usb 2.0 port outputs at 500mA and a usb 3 port 900mA.
VOID pro has a 1000mah battery, so 2 hours over usb 2 or 1.1 hours on usb 3.
cable length, and quality also effects charge rate... you could charge it off a phone charger if you want a faster charge.
Gaming PC: • AMD Ryzen 7 3900x • 16gb Corsair Vengeance RGB Pro 3200mhz • Founders Edition 2080ti • 2x Crucial 1tb nvme ssd • NZXT H1• Logitech G915TKL • Logitech G Pro • Asus ROG XG32VQ • SteelSeries Arctis Pro Wireless
Laptop: MacBook Pro M1 512gb
https://linustechtips.com/topic/865076-void-pro-charging-time/#findComment-10745938
well i have been charging it for about two hours on usb two and went to three to see if it would go faster but its still giving me an amber light....
i just changed the cable the one included is 2M
https://linustechtips.com/topic/865076-void-pro-charging-time/#findComment-10745953
