would a chip set cooler make a difference ?
i am using a gigabyte Ga-78lmt-usb3 motherboard and the north bridge chipset get to around 55*c.
would a chipset cooler be any use to me?
i always thought they where just another small pointless fan that collects dust and the bearings wont last long (for the size of the fan) but some people have said they made a difference.
thanks.
https://linustechtips.com/topic/86482-would-a-chip-set-cooler-make-a-difference/
55 degrees is nothing too worry about so just leave it as it is :)
Tor
Corsair Obsidian 650D - Intel 4770K CPU - Gigabyte G1 Sniper 5 - ASUS GTX 780 Direct CU 2 - Kingston Beast Hyperx Beast 16 GB RAM -  Corsair AX 1200i PSU - Samsung EVO drive 750 GB - Corsair AF series 120mm fans - Corsair H100i - Razer Blackwidow Ultimate 2013 edition - Razer Ouroboros - Razer Manticor - Windows 7 - Beyerdynamic MMX 300
Unless you are going for 2800MHz+, you don't need additional cooling.
[AMD Athlon 64 Mobile 4000+ Socket 754 | Gigabyte GA-K8NS Pro nForce3 | OCZ 2GB DDR PC3200 | Sapphire HD 3850 512MB AGP | 850 Evo | Seasonic 430W | Win XP/10]
