Posted November 25, 2017 So I have decided to use unRAID over freeNAS because of the ability to freely add drives to my raid whenever I want. Any recommendations or any reasons to switch to FreeNAS? Is it worth the extra cost for NAS hard drives instead of regular ones? https://pcpartpicker.com/list/TmjqD8 Link to comment https://linustechtips.com/topic/864675-help-with-nas-build/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 25, 2017 If you were going with Freenas you would need more ram. I think the rule of thumb is 8GB + 1 GB per TB of storage. So for your build it would be 8 + 4*4 = 24 GB. Link to comment https://linustechtips.com/topic/864675-help-with-nas-build/#findComment-10742902 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 25, 2017 Author 1 hour ago, danejesse1 said: If you were going with Freenas you would need more ram. I think the rule of thumb is 8GB + 1 GB per TB of storage. So for your build it would be 8 + 4*4 = 24 GB. Yeah.....I am definitely going with unraid now. Link to comment https://linustechtips.com/topic/864675-help-with-nas-build/#findComment-10743090 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 25, 2017 I've ran freenas with 12TB 3x4TB drives with just 8GB RAM before with no problems, I did this as a test to see how it performed and there were no problems at all, even running plex server too. I now have it running with 16GB and it's only using just above 8GB. Please quote my post, or put @paddy-stone if you want me to respond to you. Spoiler PCs:- Main PC build https://uk.pcpartpicker.com/list/2K6Q7X ASUS x53e - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer Displays:- Philips 55 OLED 754 model Panasonic 55" 4k TV LG 29" Ultrawide Philips 24" 1080p monitor as backup Storage/NAS/Servers:- ESXI/test build https://uk.pcpartpicker.com/list/4wyR9G Main Server https://uk.pcpartpicker.com/list/3Qftyk Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM Gaming/Tablets etc:- Xbox One S 500GB + 2TB HDD PS4 Nvidia Shield TV Xiaomi/Pocafone F2 pro 8GB/256GB Xiaomi Redmi Note 4 Unused Hardware currently :- 4670K MSI mobo 16GB ram i7 6700K b250 mobo Zotac GTX 1060 6GB Amp! edition Zotac GTX 1050 mini Link to comment https://linustechtips.com/topic/864675-help-with-nas-build/#findComment-10745109 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 26, 2017 On 25-11-2017 at 2:15 AM, danejesse1 said: If you were going with Freenas you would need more ram. I think the rule of thumb is 8GB + 1 GB per TB of storage. So for your build it would be 8 + 4*4 = 24 GB. The rule is 1GB per TB + what the OS needs, but that’s only if you’re using ZFS. On 25-11-2017 at 2:06 AM, Lightning said: So I have decided to use unRAID over freeNAS because of the ability to freely add drives to my raid whenever I want. Any recommendations or any reasons to switch to FreeNAS? Is it worth the extra cost for NAS hard drives instead of regular ones? https://pcpartpicker.com/list/TmjqD8 You can’t freely add storage to UnRAID, unless you buy UnRAID Pro, the cheaper variants have a drive limit. PC Specs - AMD Ryzen 7 5800X3D - MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT - 660p 1TBGB & Crucial P5 1TB - Fractal Define Mini C - CM V750v2 - Windows 11 Pro Link to comment https://linustechtips.com/topic/864675-help-with-nas-build/#findComment-10747972 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 26, 2017 Author 6 hours ago, NelizMastr said: The rule is 1GB per TB + what the OS needs, but that’s only if you’re using ZFS. You can’t freely add storage to UnRAID, unless you buy UnRAID Pro, the cheaper variants have a drive limit. Yeah I planned to get unRAID pro. Link to comment https://linustechtips.com/topic/864675-help-with-nas-build/#findComment-10748687 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
