Hey im planning on overclocking my i5 2500k today as im fairly bored lol :P
i have a cooler master hyper 212 evo cpu cooler what sort of speeds do you think i should try to put it up to?
also whats the best way of finding out how much the overclock has helped?
sorry if this has been posted before i had a look but couldnt seem to find any for the 2500k if there is one you know of please link :D
https://linustechtips.com/topic/86421-2500k-overclock-help/
A 212 could safely run 4.2-4.4 with adequate case ventilation and ambient temperature or more if you're brave, also any overclock will improve performance but if you really want to know there are benchmarks that you can use.
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/86421-2500k-overclock-help/#findComment-1173338
Setup Video -----------Peasant Crushing Specs----------- 4K Benchmarks
-CPU- i7 3930k @4.8GHz 1.4v -Mobo- Asus Rampage IV Extreme -GPUs- 2x GTX Titan Hydrocopper SLI -RAM- 32GB (8x4GB) Corsair Vengeance 1600MHz -Storage- 500GB Samsung 840 SSD | 2TB WD Green HDD
-Monitors- 3x BenQ XL2420T | 1x Dell U2713HM -Mouse- Steelseries Rival -Keyboard- Corsair K70 Cherry MX Brown -Headphones- Audio Techinca ATH-M50 -Microphone- RØDE NT1-A
https://linustechtips.com/topic/86421-2500k-overclock-help/#findComment-1173345
now i feel bad and blind :(
Don't worry about it, you're probably using the forum search tool which doesn't work very well. Check this out to see how to search more effectively:
http://linustechtips.com/main/topic/45264-how-to-effectively-search-the-forum/
https://linustechtips.com/topic/86421-2500k-overclock-help/#findComment-1173555
cool thanks ill try that next time :)
https://linustechtips.com/topic/86421-2500k-overclock-help/#findComment-1173605
its a sandy bridge so you should get 4.6-4.8ghz to keep up with haswell and ivybridge chips. safe 24/7 voltage is 1.38v.
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
https://linustechtips.com/topic/86421-2500k-overclock-help/#findComment-1173700
CM-212-evo can get you 4.7ghz easily enough . intel has stated 1.52v as safe - I wouldn't go over 1.45 v or 90*C which ever goes first.
most people will say 1.38v but tbh if temps are low enough thats all hogwash imho. ive ran a 2500k @ 4.7 since they released without a bit of degradation @ 1.415v.
remember evey chip is different some will do 4.5 some will do 5.0 ghz it all depends on when you hit that wall. if the scaling goes wonky and starts demanding Crazy volts for 100mhz more just stop its never worth it.
Asrock X670E Steel Legend - AMD 7600X(5.5Ghz) -  XFX Speedster-Zero EKWB Edition 6900XTXH
-32GB Kingston Fury Beast 6000mhz DDR5 - WB Black 1 & 2 TB NVME -EVGA 1300W G2
Full loop 2x480mm XSPC RX Rads / Thermaltake Pacific W8 Block
https://linustechtips.com/topic/86421-2500k-overclock-help/#findComment-1173852
Yes 1.52v is fine for benchmarking i would probably go to 1.55v. Under 1.4+v 24/7 is ok. I said 1.38 cos i'm on the stock cooler still, so that is my thermal limit. xD
Rig Specs:
https://linustechtips.com/topic/86421-2500k-overclock-help/#findComment-1174871
1.52 is your absolute max for ambient overclocking that includes watercooling imho.
https://linustechtips.com/topic/86421-2500k-overclock-help/#findComment-1189918
