Help Me Find A Head(set)?
So, I currently own a blue snowball iCE and it's causing BSOD's that i cannot fix.
. For headphones i use beats studio 1.
I'm looking for a headset now, and for the ones that are good price and seem comfortable, have a bad mic.
So i'm looking at getting this bundle:https://www.amazon.com/Audio-Technica-Professional-Headphone-Attachable-Microphone/dp/B0722KM6FX/ref=sr_1_4?s=electronics&ie=UTF8&qid=1511468656&sr=1-4&keywords=modmic+4.0
The ModMic4 alone is 50$, so i think this is a good deal? let me know.
My budget is well, near 100.
https://linustechtips.com/topic/864024-help-me-find-a-headset/
I'd recommend the Corsair Void Pro in a heartbeat, great mic and amazing speakers for something that's just 70 USD on sale on amazon right now, it's the best headset I've ever owned! And to me anyway is styled a little bit kinder on the eyes than the headset you're looking at, and i mean like... Who can say no to cheap, amazing rgb headphones, with 50mm neodymium drivers no less!
https://www.amazon.com/CORSAIR-VOID-Wireless-Gaming-Headset/dp/B0748MTZ1C/
Small edit:
Just a thing to note is that you have to decide on wether or not you'll want to use the Corsair headphones on your phone or not, as it has been shown that the AUX port version for your phone and such doesnt have the same capabilities of the purely usb version in sound quality through both the speakers and mic, however you don't notice it unless you're really picky with headphones. I'm sure this would be the same across the board with all headphones but i've only ever had the two versions of the Corsair Void, so i cant compare the different versions of others.
https://linustechtips.com/topic/864024-help-me-find-a-headset/#findComment-10737860
tbh i found the cloud IIs pretty decent for its price even for listening to music, and they are very comfortable IMO
Though the deal is quite good, but I wasn't that sold on audio technica headphones when looking for mine and testing different brands
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/864024-help-me-find-a-headset/#findComment-10737863
