Pinout for Thermaltake Pacific RGB
Solved by Metalshark,
@W-L got round to testing this and finding out the wiring required.
TL;DR they are 5V RGB LEDs and use the standard 4 wires.
Below are some photos of testing, including driving a 12V strip using the controller (taking the +12V from a molex).
In the final project I'll be using some repeaters so that the Lian Li LED50RGB-2 drives the supplied 12v strips, some Phanteks Halos frames and the Thermaltake Pacific RGB fittings.
