try deleting the temporary files. right click on the hard drive in my computer and select properties. under general tab click on disk cleanup. select all the files/folders you wish to delete to free up some potential space.
Elven
Corsair 400R, i7 3770K @ 4.5GHz 16GB, Corsair Vengeance 1600MHz, Gigabyte Z77X-UD5H Motherboard, 240GB Samsung 840 Evo Sata III SSD, 2 x Asus GTX 780 Direct CU2 SLI, Corsair H100i and Corsair AX860i Platinum Power supply.
https://linustechtips.com/topic/86375-help/#findComment-1172730
You can either try to fix it by downloading an antivirus software, or setting it back tof factory default ;)
Ok so what tool might I use to fix this
CPU: FX-8350, GPU: xfx radeon r9 290, RAM: corsair venegance 8gb, STORAGE; seagate barracuda 1TB hdd, SSDnow kingston 120gb, CPU COOLER: CM hyper 212 , CASE: fractal design XL, PSU: corsair CS 650w 80+ gold MOBO: Gigabyte GA-990FXA-UD3
https://linustechtips.com/topic/86375-help/#findComment-1172736
Did you by any chance install any new ram? The last time I installed a stick of ram my os setted my pagefile size to a ridiculous amount making my hdd fill itself up down to a few kilobytes. Like you I could retrieve the space with a restart. Once I reset the pagefile size limit back to a normal size my hdd stopped filling itself up.
https://linustechtips.com/topic/86375-help/#findComment-1172842
unless you got anybetter tricks or ideas
I habe some but the reinstall is a better option so please continue
https://linustechtips.com/topic/86375-help/#findComment-1173133
reinstall time
No.
You first need to determine why so much of your disk is occupied. Otherwise you may end up in a worse position.
Have you run disk clean up and does it report a large number of temporary or deleted files?
Have you explored the drive to see what is occupying so much space?
Have you checked the size of the swap and, if you have one the hibernation file?
https://linustechtips.com/topic/86375-help/#findComment-1173499
