Do you have problems with updating BF4? [SOLUTION]
Hi guys!
I wanted to update BF4 because there is a new patch or something but i got an error.. I have searched a little if i was the only one and i was not. I have a sollution:
  • Close Origin
  • Open Notepad
  • Copy
EnvironmentName=production
CdnOverride=akamai
  • Paste it in Notepad and save the file as "EACore.ini" on your desktop.
  • Start Origin again and then it wil ask to replace the file, click on "Yes"
It now updates but i get something like 90KB/s but it's something! :D
Please let me know if it helped! :)
[CPU: AMD FX-6100 @3.3GHz ] [MoBo: Asrock 970 Extreme4] [GPU: Gigabyte 770 OC ] [RAM: 8GB] [sSD: 64gb for OS] [PSU: 550Watt Be Quiet!] [HDD: 1TB] [CPU cooler: Be Quiet! Shadow Rock Pro Sr1]  -Did i solve your question/problem? Please click 'Marked Solved'-
I would just contact ea support and see what they recommend ?
This is just a simple fix for a temporary problem.  Allot of people got this problem.
