So as of late my PC has been having issues, they include things such as the overclock on my FX-4300 not changing, not matter what I change it to, it always just clocks up to 3.9GHz and never higher even if it's being stressed and I have been randomly losing power to stuff like my USB keyboard and mouse, any thoughts?
https://linustechtips.com/topic/862920-computer-problems/
What board are you using? How was the overclock applied? Has this overclock been stable for the past while?
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/862920-computer-problems/#findComment-10728087
I'm using a asus m5a97 r2.0, i've tired doing it in the BIOs and using their AI suite but both of them don't work and I have used the overclock for months now with now problems but it started doing this now along with the USB power problem
https://linustechtips.com/topic/862920-computer-problems/#findComment-10728099
What PSU are you using? So are you using a manual overclock or AI suite? Because you said you've tried both and neither had worked. So I'm a bit confused how you've overclocked your system, if it even is.
https://linustechtips.com/topic/862920-computer-problems/#findComment-10728121
My PSU is a Corsair CX600M(The old green ones) and for the most part I used AI suite to do the overclock so I could adjust it on the fly or turn off the overclock but after I have started to have problems I tried to overclock it in the BIOs but it didn't work
https://linustechtips.com/topic/862920-computer-problems/#findComment-10728134
