I have been planning on building a new PC for quite a while now, and am just now getting to it. I want a fairly high end gaming PC, without spending an exorbitant amount. I am looking to spend around $1500 max, preferably a little less on the PC so I can get a nice monitor to go with it. But anyways, this is the parts list I have so far
PC Part Picker Link
CPU - Intel Core i7-7700K 4.2 GHz
CPU Cooler - Cryorig H7
Motherboard - Asus Prime Z270-A
RAM - G.Skill Trident Z RGB 16GB (2 x 8GB) DDR4-3200
HDD - WD Blue 1TB
GPU - Asus ROG STRIX 1080 A8G Gaming
PSU - Thermaltake Smart Pro RGB 650W 80+ Bronze Fully-Modular
Case - Fractal Design Meshify C (I really want the InWin 805 Infinity, but I don't want to spend $250 on a case)
This is all ending up at $1322.82 after mail in rebates and with Windows 10 Home.
Another question I have is I already have a 2.5" hard drive in my laptop that I would like to use in my PC once I build it, and it already has Windows 10 on it, would I just be able to move the hard drive straight over and not have to buy Windows 10 again?
https://linustechtips.com/topic/862865-first-pc-build/
Something like this would be better...
https://pcpartpicker.com/list/2VTdsJ
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
https://linustechtips.com/topic/862865-first-pc-build/#findComment-10727633
PC Part Picker Link
HDD - WD Blue 1TB
CPU: Intel - Core i5-8600K 3.6GHz 6-Core Processor  ($279.89 @ B&H)
CPU Cooler: CRYORIG - H7 49.0 CFM CPU Cooler  ($28.90 @ Newegg Marketplace)
Motherboard: ASRock - Z370 Extreme4 ATX LGA1151 Motherboard  ($124.99 @ Newegg)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  ($159.99 @ Amazon)
Storage: Samsung - 850 EVO-Series 250GB 2.5" Solid State Drive  ($89.99 @ B&H)
Storage: Western Digital - BLACK SERIES 2TB 3.5" 7200RPM Internal Hard Drive  ($116.28 @ OutletPC)
Video Card: EVGA - GeForce GTX 1080 8GB FTW Gaming ACX 3.0 Video Card  ($574.99 @ SuperBiiz)
Case: Corsair - 200R ATX Mid Tower Case  ($39.99 @ Newegg)
Power Supply: SeaSonic - EVO Edition 620W 80+ Bronze Certified Fully-Modular ATX Power Supply  ($65.98 @ Newegg)
Total: $1481.00
Generated by PCPartPicker 2017-11-21 13:07 EST-0500
You can get Windows 10 for $5-$10 on ebay.
https://linustechtips.com/topic/862865-first-pc-build/#findComment-10727651
Change the motherboard to the cheaper and better Asrock Extreme4, the RAM to a faster kit, the SSD to the SL308, the GPU to the Strix version, and the case to a better one with TG. That would make it about right
https://linustechtips.com/topic/862865-first-pc-build/#findComment-10727668
PC Part Picker Link
HDD - WD Blue 1TB
An 8700k is better.
I believe you can...
https://linustechtips.com/topic/862865-first-pc-build/#findComment-10727686
I know that an 8600k would be better than the 7700k, but with the deals on the 7700k and motherboard combo it is almost $100 more to get the 8600k, if I can for sure just use the windows that I already have then I wouldn't even hesitate, but if I need to buy Windows 10 again, is it really worth it?
https://linustechtips.com/topic/862865-first-pc-build/#findComment-10727745
