Could be HDD Damage.
Quote
The error code: 0xc0000001 indicates that there might be some issues with the booting device or some booting files are corrupted. It might also happen if some problem happens with the boot sector of the computer.
Fan Comparisons          F@H          PCPartPicker         Analysis of Market Trends (Coming soon? Never? Who knows!)
Designing a mITX case. Working on aluminum prototypes.
Open for intern / part-time. Good at maths, CAD and airflow stuff. Dabbled with Python.
Please fill out this form! It helps a ton! https://linustechtips.com/main/topic/841400-the-poll-to-end-all-polls-poll/
https://linustechtips.com/topic/862830-help/#findComment-10727421
If you have another computer (or HDD), you could check by replacing the HDD and booting off of Linux or something.
I'd double check the SATA connections, etc.
Here's a troubleshooting list of sorts, but I don't know if it's applicable in your case.
Quote
Method 1:
I would suggest you to un-plug all external devices, except the keyboard and mouse, then try to boot the computer.
Method 2:
I would suggest you to try performing Startup Repair using Windows 8 installation media from Windows Recovery Environment (WinRE) and check.
To perform Startup repair on your computer, follow these steps:
a. Insert the media such as (USB or DVD) and restart your computer.
b. Press F12 key (typically this is F12, but it can differ between computer manufacturers) and choose the drive that you inserted the installation media into.
c. Once the Windows Setup window appears, follow these steps:
d. Click next and select Repair your computer.
e. You will then see a blue screen and an option to choose. Choose the option Troubleshoot and select advanced options.
f. You may choose StartupRepair from Advanced boot option.
g. Follow the on-screen instructions to complete the Startup Repair.
Method 3: If automatic repair fails, you may try to repair them using these commands through Command Prompt under Advanced Options. Follow the steps:
a. After you boot your computer using Windows 8 installation media, a black screen appears with gray text Press any key to boot from CD or DVD. Press any key.
b) Select the correct time and Keyboard type.
c) Click Repair your computer in the lower left corner.
d) Select Troubleshoot from Choose an option screen.
e) Click Advanced options in Troubleshoot screen.
f) Click on command Prompt.
g) Type these following commands and hit enter after each line of command:
Bootrec /fixmbr
Bootrec /fixboot
Bootrec /scanos
Bootrec /rebuildbcd
Restart the computer and check the issue.
7
https://linustechtips.com/topic/862830-help/#findComment-10727432
