hi everyone!
I´m building my set up step by step as the money allow me to do
and I bought two monitors ( asus MG28UQ) and was only using one of then with my laptop
today i received the adapter so I could finally connected both of then on my laptop
but now I´m not being able to reconize the 3 displays
somehow windows only reconizes the display from the laptop itself
and both monitors (asus) are displaying the same image
I have no idea on how to fix this issue
https://linustechtips.com/topic/862768-3-displays-problem/
So, when you say it only recognizes the laptop display only, if you go into graphics properties (for whatever gpu/apu integrated graphics you have) does it show more than one display?
If so, in graphics properties make sure the display is set as extend this display.
https://linustechtips.com/topic/862768-3-displays-problem/#findComment-10726881
sorry if I express myself poorly, the image from the laptop display is fine, the problem is with the other two monitors,  they are showing as if they were only one, so right now i have the laptop display and the other two are as if they were only one20171121_160950.thumb.jpg.75ac6e419bcc18bb12c67469a25a8760.jpg
https://linustechtips.com/topic/862768-3-displays-problem/#findComment-10726910
That is the wrong adapter. That will only split the output from your laptop to 2 monitors, making 2 monitors show the same screen like you are seeing. If you are looking to have the monitors as individual displays, you need an external video card or a USB display adapter like This One
https://linustechtips.com/topic/862768-3-displays-problem/#findComment-10727306
I´m so stupid bought the wrong stuff........
thanks man!!!
https://www.amazon.de/XCSOURCE-Adapter-Konverter-Notebook-AH150/dp/B01ER2Z2HM/ref=pd_sim_147_2?_encoding=UTF8&psc=1&refRID=XSCKQKKJB4AEWWD22E18
this one also would get the job done?
connecting one monitor into the HDMI that already existed at my laptop and the other monitor connected to one USB port with this adapter?
https://linustechtips.com/topic/862768-3-displays-problem/#findComment-10727509
thanks man!!!
It doesn't look like that one supports 4K
https://linustechtips.com/topic/862768-3-displays-problem/#findComment-10727563
Quote
thanks man!!!
What kind of display outputs does your laptop support?
You may need a laptop with a more robust output solution. I don't believe it's possible to run two *independent* displays off one HDMI signal/cable.
That sort of workload is only doable with DisplayPort. Does your laptop have a DisplayPort output?
I don't believe your monitors support daisy-chaining so you'll need what's called an MST hub.
https://linustechtips.com/topic/862768-3-displays-problem/#findComment-10729295
@LyondellBasell @Flurpster thank you guys for your inputs, my laptop doesnt has a displayport eventhough it has two graphic cards
but I dont have access to  then to connected each monitor in one....... ill exchange the gadget  that i bought as it doesnt do what i though it does and buy the connectors recommended
once again thanks for all the feedback
https://linustechtips.com/topic/862768-3-displays-problem/#findComment-10746620
