Good day! I am planning to build this :
https://de.pcpartpicker.com/list/qTHPjc
Now I want to use this to play some esports titles and stream as well. Please let me know if this build will suffice for my needs.
I am currently using my laptop with this specs:
intel core I5-337U 1.90 ghz
8gb Ram
and an Nvidia Geforce 720m
so Lastly my question is: would you suggest getting a capture card and try to stream on a 2 pc setup? or will it be fine just using the pc I am planning to build?
https://linustechtips.com/topic/862197-planning-my-first-build/
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  (€174.17 @ Amazon Deutschland)
CPU Cooler: CRYORIG - H7 49.0 CFM CPU Cooler  (€34.90 @ Caseking)
Motherboard: ASRock - AB350M-HDV Micro ATX AM4 Motherboard  (€65.60 @ Amazon Deutschland)
Memory: Kingston - Savage 8GB (1 x 8GB) DDR4-3000 Memory  (€96.30 @ Amazon Deutschland)
Storage: SanDisk - SSD PLUS 120GB 2.5" Solid State Drive  (€54.99 @ Amazon Deutschland)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (€43.55 @ Amazon Deutschland)
Video Card: Asus - GeForce GTX 1060 6GB 6GB Turbo Video Card  (€230.45 @ Amazon Deutschland)
Case: Corsair - SPEC-02 ATX Mid Tower Case  (€56.99 @ Amazon Deutschland)
Power Supply: Corsair - VS 550W ATX Power Supply  (€48.48 @ Mindfactory)
Total: €805.43
Generated by PCPartPicker 2017-11-20 10:28 CET+0100
You'll notice I switched you to an air cooler.  It gives slightly better performance, but it's a lot cheaper.  The faster RAM and better GPU will be worth it in the end.  I got rid of the crappy MSI board.
Make sure to quote or tag me (@JoostinOnline) or I won't see your response!
PSU Tier List  |  The Real Reason Delidding Improves Temperatures"2K" does not mean 2560×1440
https://linustechtips.com/topic/862197-planning-my-first-build/#findComment-10721565
So, you don't need a liquid cooler for that cpu, but it doesn't hurt. If I were you I would get a noctua nh-u12 but make sure it has am4 mounts. If you plan on streaming esport type games like overwatch or csgo, League of legends stuff like that you should be fine. If I were you though, I might look at getting 16gb of ram, and maybe a 1060 instead, they overclock much better. but I have personally never owned an rx570
https://linustechtips.com/topic/862197-planning-my-first-build/#findComment-10721566
6 minutes ago, NotTristan said:
If you are getting 8gb why get 2x4, limits ram upgrades in the future.
Because it was a lot cheaper than a single stick, and I was trying to make up for the extra cost of high frequency RAM.  He's still got two free slots.
Edit: Switched to a better board.  It's micro though, so I used a single 8GB stick.
https://linustechtips.com/topic/862197-planning-my-first-build/#findComment-10721576
3 minutes ago, JoostinOnline said:
This is more expensive, but it will give you significantly better performance:
CPU Cooler: Cooler Master - MasterLiquid Lite 120 66.7 CFM Liquid CPU Cooler  (€44.21 @ Amazon Deutschland)
Motherboard: MSI - B350 TOMAHAWK ATX AM4 Motherboard  (€95.99 @ Amazon Deutschland)
Memory: Kingston - Savage 8GB (2 x 4GB) DDR4-3000 Memory  (€85.82 @ Amazon Deutschland)
Total: €869.55
Generated by PCPartPicker 2017-11-20 10:13 CET+0100
You'll notice I switched you to an air cooler.  It gives slightly better performance, but it's a lot cheaper.  If you have to save up a little, do it anyway.  The faster RAM and better GPU will be worth it in the end.
You left the AIO in there.
Intel i7-7700k @ 5.1ghz | Asus ROG Maximus Hero IX | Asus ROG Poseidon Platinum 1080ti @ 2126mhz | 64gb Trident-Z DDR4 @ 3600mhz | Samsung 960 Pro 1tb @ 3500mbps/2500mbps | Crucial 240gb SSD | Toshiba 4tb 7200rpm HDD w/ Crucial 128gb SSD cache | Corsair Hx1000i PSU | EK 360mm Coolstream XE Radiator | EK-Supremacy Evo Waterblock | EK-DDC 3.2 PWM Elite Edition Pump | EK-RES X3 150 RGB Reservoir | Primochill AdvancedLRT Clear Tubing | Primochill VUE UV Blue Coolant | Corsair 570x Crystal RGB Case | 4x 30cm CableMod UV/RGB Widebeam Hybrid Led Strip | 3x 120mm Corsair SP120 RGB Fans | 3x Noctua NF-A14 iPPC 3000rpm Fans | 3x Noctua NF-A12x15 Fan | CableMod ModFlex PSU & SATA Cables | Asus ROG Swift 27" 4k IPS w/G-Sync & LG UD68 27" 4k IPS w/Freesync |
https://linustechtips.com/topic/862197-planning-my-first-build/#findComment-10721578
LMAO, fixed.  xD
I also made a couple changes.
https://linustechtips.com/topic/862197-planning-my-first-build/#findComment-10721586
you don't need an aftermarket cooler. Just use the one included. My friend has the same cpu and he streams fine. Also this system is very similar to mine. Looks good. But definitely go with nvidia because shadowplay is very optimised for streaming.
PC Specs:
CPU: Intel Core i7-12700K 3.6 GHz 12-Core
CPU Cooler: Corsair iCUE H150i ELITE CAPELLIX 75 CFM Liquid CPU Cooler
Motherboard: Asus ROG STRIX Z690-E GAMING WIFI ATX LGA1700
RAM: Kingston FURY Beast 32 GB (2 x 16 GB) DDR5-5200 CL40
Storage: Boot Drive: Samsung 960 Evo 250GB M.2 NVMe SSD
               Other Storage: Mass Storage: Western Digital Caviar Blue 1TB 7200 RPM, Western Digital Caviar Blue 2TB 5400 RPM, Scratch Disk: Intel X25-E SSDSA2SH032G1 32GB SATA II SSD, Backup Drive: Seagate ST3160318AS 160GB HDD
GPU: Asus GeForce RTX 3080 Ti 12 GB ROG STRIX GAMING OC
Case: Corsair 5000D AIRFLOW ATX Mid Tower
PSU: Silverstone Strider Platinum S 1000 W 80+ Platinum Certified Fully Modular ATX
OS: Windows 11 Pro 64-Bit
Monitors: Primary: Samsung S34E790C 34" 3440*1440 60 Hz UWQHD; Secondary: LG 34UM58-P 34" 2560*1080 75 Hz UWFHD; Tertiary: BenQ GL2460 24" 1920*1080 60 Hz FHD
Keyboard: Corsair K70 Mk. 2 RGB Gaming Keyboard - Black
Mouse: Corsair M65 Pro RGB FPS Gaming Mouse - Black, Logitech MX Master 3
Headphones: Corsair VOID PRO Surround Cherry 7.1ch
Speakers: Logitech Z213 7W 2.1ch
Laptop:
Asus Zenbook Pro 15 (UX535Li-E2018T) with Intel Core i7-10750-H 12MB @ 2.60GHz (Turbo @ 5.0 GHz), 16GB (2 x 8GB) DDR4 2933 MHz SODIMM and Intel(R) UHD Graphics; NVidia Geforce GTX 1650-Ti with Max-Q Design, using WDC NVMe PC SN730 SDBPNTY-1T00-1102, on a 96-Wh battery
NAS Specs:
Make & Model: QNAP TS-1277
CPU: AMD Ryzen 5 1600 @Stock
Hard Drives: x8 WD Red 2TB
SSDs (2.5"): x1 Samsung 850 Evo 250GB V-NAND (cache drive)
M.2 SSDs: None
RAID Configuration: RAID 6 (excluding SSD)
Total Storage: 12TB
Expansion Cards: None
https://linustechtips.com/topic/862197-planning-my-first-build/#findComment-10721720
thanks for all your input. lastly I have a question about video cards. I checked amazon and I saw other gtx 1060 6gb cards that are cheaper. Im just not sure whats the difference with this brands. is it ok to go for something cheaper but is still a gtx1060 6gb?
https://linustechtips.com/topic/862197-planning-my-first-build/#findComment-10726603
