i recently got a job and want a better gaming computer with no fps problems what is the best setup foor gaming and maybe streaming? this is what i picked out : https://gyazo.com/42e5dd024b35eb1372f41c7215979d02
i had a i7 picked before but ive heard if ur not rendering or editing anything its not worth to get a i7 but im not sure if i should get it because i want to stream and play?
https://linustechtips.com/topic/862180-need-help/
i'm running very similar specs and i would say at least get an i5 7600k like $5-$20 more slightly higher boost so potential higher overclock i've overclocked my 6600k to 4.5 without adjusting power
as for fps with a 6600k and 1070 ftw 8gb and 16gb ram i still will have to turn down settings in some games without streaming you'll never be max settings in all games no worries unless moneys no worry.
https://linustechtips.com/topic/862180-need-help/#findComment-10721470
so get better i5 and 8gb ram. i wouyld stream games like csgo and i dnt really play on high settings.also play 4:3 1024x768 so i should still get a cinsistent 220fps?
https://linustechtips.com/topic/862180-need-help/#findComment-10724662
1 hour ago, Riboflavin64 said:
oh yea no prob i was talking about like the newest triple A titles
i really dont play any games like destiny 2 and stuff like tht. i might try pubg not streaming. i will most likely play csgo, h1z1, rust, fortnite, and games like tht. would i be able to stream with consistent high fps ini thsoe titles?
https://linustechtips.com/topic/862180-need-help/#findComment-10725591
