4k 32" monitor with Gsync
Col. Sandurz
Hello everyone.
I am looking for a 4k 32" 16:9 monitor with Gsync (i'd like more a 30" 16:10 panel, but i'd have to desing and manifacture the panel myself which is highly unlikely).
Ideally (again i know it is probably impossible) it should display lower resolutions at higher refresh rates than the usual 60 hz.
If it can be oriented in portrait, all the better.
I was considering the Acer XB321HK (which does not rotate and has a top refresh rate of 60 hz) but i have read that the panel has some glitches that are probably impossible to fix.
I wouldn't like spend more than the Acer costs.
Is there (or is going to be there in a reasonable amount of time, months not years) anything out there?
  • 3 months later...
Basically what i need is a monitor that is big and hi res for work and stuff (hence the 32" - 4k) but could run higher refresh rates for games even at "low" res, like 1080p.
