So, i have had my computer for almost a year now. But lately, it has frozen randomly while i play games. i have tried to check the heat of each component when it freezes, but nothing has been out of normal. It just leaves the latest picture on the screen, and i cant do anything but turn the computer off manually. If i had been in a call with friends, i cant hear them either. It doesnt leave any error messages.
Specs:
Im running windows 10
CPU: Intel Core i7-6700
RAM: DDR4 16GB
Motherboard:
GPU: NVIDIA GeForce GTX 1070
https://linustechtips.com/topic/861515-pc-freezing-randomly/
Do you know if any component is at it max usage? Like 100% cpu or 100% RAM usage? Check with task manager.
My own build: RΛZΞR theme
CPU: Intel Core i5 7600K // CPU cooler: Cryorig H7 // Motherboard: MSI Z270 gaming pro carbon //
Video Card: MSI Armor gtx 1070 OC 8GB // RAM: Corsair Vengeance 16GB 3200MHz //
SSD: Samsung EVO 960 500GB // HDD: 2x WD yellow edition 2TB //
Case: NZXT H440 RAZER edition // Power Supply: Corsair RM550x //
Operating Software: Windows 10 pro 64-bit
https://linustechtips.com/topic/861515-pc-freezing-randomly/#findComment-10715449
Just now, 7znorum said:
Not the Ram or cpu, but the disk tends to be at 100%.
Which drive do you use while gaming?
https://linustechtips.com/topic/861515-pc-freezing-randomly/#findComment-10715460
1 minute ago, 7znorum said:
TOSHIBA DT01ACA200
Is the game using all this power (usage) or are it other programs using a lot as well?
https://linustechtips.com/topic/861515-pc-freezing-randomly/#findComment-10715469
yeah
So the game is using all this power? (If I understood correctly)
Try a windows quality check: go to all folders --> right click your disk on the left --> go to properties --> go to tools --> click check
You could also try crystaldiskinfo
https://linustechtips.com/topic/861515-pc-freezing-randomly/#findComment-10715482
and the gpu
GPU tend to work at 99% usage most of the time. Check if it's overheating or lowering the boost clock.
https://linustechtips.com/topic/861515-pc-freezing-randomly/#findComment-10715489
i scanned it, and there were no problems found
https://linustechtips.com/topic/861515-pc-freezing-randomly/#findComment-10715498
 Download crystaldiskinfo and run a test. Check the hard disk health and SMART.
I would try download a (low gb) game on your SSD (if you have one) and look if it does the same freeze. If so we know it’s not the HDD
https://linustechtips.com/topic/861515-pc-freezing-randomly/#findComment-10715571
