Ok so i was on redit yesterday, and clicked a link not knowing what is was, it took me to a porn site, or at least a site with porn, i exited the second i found out what is was. (cant remember site) Now im just wondering was this enough to get my pc infected with any sort of malware. i scaned my pc using MSE nothing came up.
thanks for you help
https://linustechtips.com/topic/86060-help-maybe-malware/
nothing to worry about .. you shouldn't be so skeptic, it usually takes more than that go get any malicious malware.
Yeah, it's very, very unlikely that simply visiting the site would give you any sort of virus. They're usually contracted through installing an infected program.
https://linustechtips.com/topic/86060-help-maybe-malware/#findComment-1169062
ok its just ive never been hit by a virus and i dont want to start becouse of my stupifity ok clicking before i check
https://linustechtips.com/topic/86060-help-maybe-malware/#findComment-1169141
man .. your title is just the worst, but for whatever reason i love it!
as zember said, you usually get it through downloading something infected, usually called a trojan virus, there is the chance of being struck through adds aswell but that usually isn't anything harmfull or agressive, it normally takes a pretty big screw up to contract anything harmfull.
i can relate to wanting to keep your new pc as clean as possible :).
Edit: well yes, i guess it would be more accurate to say install rather than download :P.
https://linustechtips.com/topic/86060-help-maybe-malware/#findComment-1169193
Haha, did it trick you?  :D
Just want to clarify, simply downloading a file without installing it won't give you a virus, as far as I know. It's when you install it that it can definitely be a problem.
https://linustechtips.com/topic/86060-help-maybe-malware/#findComment-1169206
Did you accidentally clear your browsing history too?
Intel i5 6600k~Asus Maximus VIII Hero~G.Skill Ripjaws 4 Series 8GB DDR4-3200 CL-16~Sapphire Radeon R9 Fury Tri-X~Phanteks Enthoo Pro M~Sandisk Extreme Pro 480GB~SeaSonic Snow Silent 750~BenQ XL2730Z QHD 144Hz FreeSync~Cooler Master Seidon 240M~Varmilo VA87M (Cherry MX Brown)~Corsair Vengeance M95~Oppo PM-3~Windows 10 Pro~http://pcpartpicker.com/p/ynmBnQ
https://linustechtips.com/topic/86060-help-maybe-malware/#findComment-1169448
