Beats Wireless Earphones?
Go to solution Solved by Chasingsilver,
Ah thanks.
Have you a beat X? I could afford the beats X and the Powerbeats 2 I can pick them up for about 50£ I would only use them at the gym good idea? I really like the apple ear pods sound wise would you say the beat X sound better?
Cheers.
Hi
Just wondering all looking for a good pair of wireless headphones.. I was looking at the Beats X and the powerbeats 3 they both look good, But I prefer the Beat X as they look better, They would be used general use college, running etc. Only problem I herd that the beats X isn't sweat proof but then I've also herd that it can hold up? I don't like the look of the powerbeats kinda look a bit off for casual use if you get me. any one have either of these? any other I should look out for?
https://linustechtips.com/topic/859797-beats-wireless-earphones/
Well, if you better bass (typical of Beats users) and looks, check out Crazybaby Air.....
 Main Rig: AMD AM4 R7 5700X3D (8C/16T) + TR Phantom Spirit 120 EVO | Gigabyte X570 Aorus Xtreme | 2x 16GB Kingston Fury Beast DDR4 3600 | XFX MERC 310 RX 7900 XTX | 256GB Sabrent Rocket NVMe M.2 PCIe Gen 3.0 (OS) | 4TB Crucial P310 NVMe M.2 PCIe4x4 | 2TB TG Cardea Zero Z440 NVMe M.2 PCIe Gen4x4 | 4TB Samsung 860 EVO SATA SSD | 2TB Samsung 860 QVO SATA SSD | 6TB WD Black HDD | CoolerMaster H500M | Corsair HX1000 Platinum | Logitech G915 + G303 Shroud Ed + 8BitDo Ultimate 2.4G | iFi Micro iDSD Black Label | Philips Fidelio B97 | C49HG90DME 49" 32:9 144Hz Freesync 2 | Omnidesk Pro 2020 48" | 64bit Win11 Pro 24H2
2nd Rig: AMD AM4 R9 5900X (12C/24T) + TR PA 120 SE | Gigabyte X570S Aorus Elite AX | 2x 16GB Patriot Viper Elite II DDR4 4000MHz | Sapphire Nitro+ RX 6900 XT | 500GB Crucial P2 Plus NVMe M.2 PCIe Gen 4.0 (OS) | 2TB Adata Legend 850 NVMe M.2 PCIe Gen4x4 |  2TB Kingston NV2 NVMe M.2 PCIe Gen4x4 | 4TB Leven JS600 SATA SSD | 2TB Seagate HDD | Logitech G613 + G703 | SOLDAM XR-1 Black Knight | Enermax MAXREVO 1500 | 64bit Win11 Pro 24H2
HTPC: AMD R7 6800H | 32GB DDR5 4800MHz | AMD 680M iGPU | 2TB SSD (2 Partitions 400GB + 1.4TB)) + 1TB SSD | Logitech G613 + G304 | Win11 Pro  24H2
Laptop: Lenovo Legion 5 Pro 16ACH6H - AMD 5800H | 32GB DDR4 3200MHz | 680M iGPU | 1TB Kingston NV1 NVMe M.2 (OS) | 4TB Lexar NM790 SSD | Win11 Pro
13 minutes ago, Chasingsilver said:
Beats X
It is a physical around neck wireless earbud meaning it can be worn all day without even noticing its there. Beats X isn't sweat proof comment is sort of invalid because you'll never get sweat into the Beat X's internals due to its design and sweat inside of earbuds aren't a problem.
powerbeats 3
It is marketed as a workout headset. Not meant to be worn all day. And even if you wear it all day, it is noticeable unlike the Beat X. It will dangle and it will be mildly uncomfortable if worn all day. I am comparing the Beats X's wearability to the Samsung Level U pro which is the same all day neck design.
The microphone for the powerbeats ARE NOT sweatproof, it will short circuit if sweat gets in there when working out. Thus the infamous random pausing, random track skipping, etc.
Ah thanks.
Cheers.
