Monitor recomendations
Jbonn386
HI so my current computer in my setup is using a 1070 so graphics wise 4k is a stretch i even think 144 @1440p might be difficult to acheive.
So i am in the market hoping to pick up a monitor on Black Friday/Cyber Monday my goal is 75-100hz on a 32 inch panel. i'm not sure about ips i am a little ocd when it comes to the glow/backlight leaks.
Also not sure if at 32 inch size i should be looking at curved to avoiding angle viewing problems.
the ASUS PB328Q was one monitor i was looking at and so far its leading but hence the curved question above.
preferably i would like to keep it under 500$
Main PC = I5 7600K @4.5ghz, Asus Gtx1070, 16GB DDR4 3000Mhz, 480GB SSD, Msi Z270 Mobo.
What do you plan to do with it? Editing, gaming or both?
Try using the PSU Tier List!
How to reset the bios/clear the cmos
My current rig:
CPU: Ryzen 7 3700x
Ram: 1x16gb DDR4, 2x8gb DDR4
Storage: 1tb nvme ssd
GPU: gtx 3080
Monitor: 23.8" Dell S2417DG 144hz g-sync 1440p + 27" Acer S271HL 60 Hz 1080p
Keyboard: ducky one I | I SF
Mouse: gpro wireless | glorious model o2 wireless
Sound : beyerdynamic 1990 pro | Monoprice liquid spark (amp) + topping d10 (dac)
Gaming and watching youtube/twitch/movies ect just media consumption.
I'd go for a 1440p or 1080p 144hz monitor, just because the 1070 is a great card and could most likely do 1440p 80+ fps in most games. EDIT: A 1080p 144hz monitor might not look as stunning, but it will run at a much higher frame rate.
My current rig:
CPU: Ryzen 7 3700x
GPU: gtx 3080
I currently have a 24in 1080p 144hz monitor i would use as a fps shooter one but atm most of my shooter games are on XBox one just cause friends and i play single players on the comp for that graphic goodness
I wouldn't get 1440p @ 32", it's not dense enough and you're basically just getting a 24" 1080p experience.
Monoprice has a 32" 4k HDR monitor for $399. I'd get that. It's $70 cheaper than the Asus.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
I don't think you need 144hz for single player then.  A good 1440p 70-100hz display will do like this one: https://pcpartpicker.com/product/YZn2FT/benq-monitor-gw2765ht
or another from here: https://pcpartpicker.com/products/monitor/#r=344001440,256001440&H=60,240&X=0,44520
will do just fine.
My current rig:
CPU: Ryzen 7 3700x
GPU: gtx 3080
