Hey Linustechtips forum!
I'm new to the forum and English isn't my native tongue. I recently bought a Asus gtx 1080 Video card for my pretty old PC, i know from the bottlenecks. But when i installed it and powered it up it worked great i had idle temps around the 30°C's and under load temps form 60°C to 70°C with custom fan controls. But recently my HDD died and had to reinstall windows. I know, I don't have my OS on the HDD but something weird happened with the installation and (ended up with a little bit of windows on my HDD)  if that possible... somehow. Anyway after the reinstalling Windows 10, geforce experience, drivers and applications. I noticed that the temps where getting close to the 100C and this with the default ''gaming mode'' profile in GPU tweak II. After i set the fan controls to my custom one. I will get temps from 83°C average so a little improvement. I have tried to overclock my GPU on the previous installation of windows. But this didn't do any thing because of the bottleneck from my CPU. I currently have the Intel i5 4460. Personally i'm not a great fan of high temps on my PC. I don't mind fan sound but on auto fan control my fan speed was 100% that was quite annoying obviously.
I don't know if this has any thing to do with my GPU but i want to give you the best information to help me troubleshoot/fix this problem. I also have issues with Full-screen and border-less screen on my Asus ROG swift pg279q in Battlefield 1. Whenever i set the settings on Full-screen or border-less the screen will freak out, turning black, closing BF 1 window opening it again so on and so so forth. Sometimes when i alt tab the video setting will be set to default. In World of Warcraft when in loading screen my second monitor just freezes for the duration of the loading time and when i move my cursor it is just fine.
I apologize for the English error's but this problem is getting real annoying real fast.
Feel free to ask me anything
your sincerely, Silvan
Edited by SilvanSchinkel
Pressed enter on accident
https://linustechtips.com/topic/859321-need-help-trouble-shooting/
Install MSI Afterburner and try monitoring what's happening with the graphics card.
Is something using the graphics card a lot? Are the fans spinning?
Want to know which mobo to get?
Choose whatever you need. Any more, you're wasting your money. Any less, and you don't get the features you need.
Only you know what you need to do with your computer, so nobody's really qualified to answer this question except for you.
chEcK iNsidE sPoilEr fOr a tREat!
I Will try msi afterburner and yes the fans are spinning real loudly. no just the game and a second monitor with YouTube or twitch.
1 minute ago, TheGlenlivet said:
Just to clarify; you have not changed your CPU, only the HDD?  Did you take anything else apart when changing the drive?  Is the new drive in a location that is blocking airflow that the old drive was not?
Nope the HDD is in the same place as the old one.
The first thing that went to my head is that it can maybe be a virus that went into your PC and now you are "mining" for someone else. Just guessing....
What is the GPU usage (Install GPU-Z) and maybe even look up your CPU usage to while you're at it (CPU-Z).Try installing Malwarebytes and scan your PC... I'm really curious
To be an expert is to know more about less.
  • 2014 Build --> FX 8350 4.7GHz {} ASRock Fatal1ty 990FX Killer {} Reference GTX 980 4GB {} 2x4GB 1866MHz HyperX {} Seagate 2TB 7200rpm {} 840 EVO 120GB {} XFX PRO850W {} Noctua NH D14 {} Fractal Define R4 White Windowed
  • 2018 Build --> Ryzen 7 2700X {} ASRock Fatal1ty X470 Gaming K4 {} Gigabyte RTX 2070 8GB {} 2x8GB HX Fury 3200MHz {} Toshiba P300 2TB {} Kingston 480GB A1000 {} Corsair RM750W {} Enermax LIQMAX II 240 {} Fractal Focus G
  • 2021 Build --> Ryzen 9 5900X {} ASUS ROG Strix X570-F GAMING {} ASUS GeForce RTX 3080Ti ROG STRIX OC {} Gigabyte AORUS RGB DDR4 32GB {} Kingston KC2500 M.2 2280 NVMe 2TB {} Seasonic FOCUS GX-1000 {} ASUS ROG Ryujin 240 AIO {} NYXT H710i
  • 2026 Build --> Ryzen 9 9950X3D {} ASUS ROG CROSSHAIR X870E HERO {} ASUS GeForce RTX 5090 32GB ASTRAL LC {} G.Skill TridentZ Royal Neo RGB Silver DDR5 CL28 6000MHz 2x16GB {} Samsung SSD 4TB 9100 PRO M.2 {} Seasonic 1600W PRIME TX Noctua Edition {} Fractal Lumen S36 V2 RGB 360mm AIO {} Fractal Design North XL Charcoal
I ran malware-bytes and it did'nt found anything. As of the CPU usage i don't see anything of off the ordinary
Have you tried re-installing windows
No i did not i just installed it like a week ago this made it sound that i reinstalled it for the problems i'm having now. But im gonna try that real soon.
I mean this problem happened when you installed windows. Like you said
Quote
Try formatting the HDD and installing it again.
no this was on my previous installation. i but then my hard drive died and could replace it because of the weird problem. I reinstalled and reformatted everything after this. But i will try reinstalling windows this night
