I have zero clue where to post this but here's the deal I got a 1-year-old pc the one that I'm using right now I'm gonna get a big boy pc soon. What do I do with this one is it possible to take out my graphics card and put it on the new one like to have 2 will that even help my new pc can I turn this pc into something more idk help :D
Motherboard:  GA-970A-UD3P(rev 2x)
GPU: Radeon R9 390
CPU: FX 6300 Six-Core 3.50 GHz
I dont think the rest matters :/ but I will edit if you want :D
https://linustechtips.com/topic/859215-need-help-with-old-pc/
GPU: Radeon R9 390
is this custom or prebuilt? if this is custom, its easy to take the graphics card out.
 as long as your new motherboard has two pci slots, then you can put two graphics cards in.
Rx580 Red Devil
Msi b40 tomahawk
Ryzen 5 2600
NZXT H500
Arctic Freezer 33
EVGA supernova 650 watts 80+ gold
3x WD caviar blue 1tb HDD
1x Corsair SSD
https://linustechtips.com/topic/859215-need-help-with-old-pc/#findComment-10692140
7 minutes ago, Dutch-stoner said:
It all depends on your next "big boi pc". Can you re-use the PSU. SSD. HDD. Case and so on. (will it use DDR3 or 4 memory)
If it's a "big boi PC", I sure hope it'll be a new platform running DDR4.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/859215-need-help-with-old-pc/#findComment-10692169
yes it is custom my friend built it for me but this time im on my own D:
https://linustechtips.com/topic/859215-need-help-with-old-pc/#findComment-10692176
4 and ima use new everything i just dont know what ima do with this pc lel i bet it can use the hdd tho i dont have ssd D:
https://linustechtips.com/topic/859215-need-help-with-old-pc/#findComment-10692185
1 minute ago, tony249245 said:
indeed it is :D
Basically what he said then. Drives, PSU, case fans, and even the case if you want to, can be reused for your next build. Heck, if you have an aftermarket CPU cooler, you might be able to get the mounting hardware for AM4 from the manufacturer if you ask them.
https://linustechtips.com/topic/859215-need-help-with-old-pc/#findComment-10692193
perhaps :D
https://linustechtips.com/topic/859215-need-help-with-old-pc/#findComment-10692201
1 minute ago, Dutch-stoner said:
When everything in your "big boi pc" is new, just sell the old one. (or find a use for it, while keeping it working) There are ALOT of uses for an older pc like that.
well thats why im here also tell me what are some good uses m8
https://linustechtips.com/topic/859215-need-help-with-old-pc/#findComment-10692213
