I bought a used system and want to bling it buy adding a window and some LED strips, but the seller had smoked next to it for some time and its quite badly stained with tar residue. After tearing it down and pressure washing the case what's the best way to clean the components like the GFX Heat sink, case fans and mainboard (if possible)  .. ?
https://linustechtips.com/topic/859196-deep-cleaning-dirty-system/
with rubbing alcohol just like what you do with thermal paste
ask me about your system builds, AIO's, CPU's, PSU's, and GPU's.
