Hi to everyone,
    I'm looking forward to buy a pair of headphones, My budget is around 50-60€, I was interested in the AKG M220 Pro on Massdrop (which, btw, if anybody has experience with, I'd like to ask a couple of things), but I didn't really look into it too much cause I saw it yesterday and I didn't want to make a rushed decision.
Now I saw there are on a huge discount the Sony MDR-ZX770BN on Amazon, at 60 €, but I can't find a lot of reviews on it so again, I don't really know what to do, are they indeed good quality o not? Is it a good deal? And other than that, what are the best headphones you would advice me to buy for 50-60€ considering that I'll mainly use them to play music on my pc and phone?
Thanks a lot.
https://linustechtips.com/topic/859148-first-headphones/
26 minutes ago, RAM555789 said:
Depends, are you looking for open or closed headphones? They both have advantages and disadvantages to consider
Well, I think closed Headphones cause I don't really want people to tell me to turn down the volume or just straight up listening to what I am listening (is Linus exagerating about the fact that you can hear pretty much clearly what is going on inside?), but I have to say that I have never tried open headphones so I wouldn't know if the difference in sound could be worth it, if you could give me an advice on both types it would be awesome, I'll also try to go to a store to test out the difference between the two.
https://linustechtips.com/topic/859148-first-headphones/#findComment-10691583
Definitely, see if you could try both out, but as for use if your going to be out and about or have a noisy house, I would go with closed headphones, if you want the best sound possible and your going to mainly use it in your house, and your house is relativly quiet, then I would go for open. I myself went for used logitech G930s. They only work with USB wireless reciver but for someone like me who doesnt use them with a phone they were fantastic closed headphones.
https://linustechtips.com/topic/859148-first-headphones/#findComment-10691681
1 hour ago, johnukguy said:
Neither of those two. These ones are just better than both of them and are cheap:
Checked them out, they seem great but unfortunately here they cost around 170 € for some reason... :(
Quote
1
I tend to listen to music on my phone rather frequently so they wouldn't be an option for me
https://linustechtips.com/topic/859148-first-headphones/#findComment-10691696
As long as your computer can use them, I would find some good Bluetooth, headphones. I have class but I could look around for a pretty good pair once I'm done.
https://linustechtips.com/topic/859148-first-headphones/#findComment-10691758
If you can help me find something it would be really nice of you, but I gotta say... why don't you like standard jack ports? xD
https://linustechtips.com/topic/859148-first-headphones/#findComment-10691780
Once you go cordless you never look back, yeah you gotta charge them, but I love wireless, I could come up with corded options alongside wireless. One question though, do you need a microphone with this headset?
https://linustechtips.com/topic/859148-first-headphones/#findComment-10691797
If there is the option it doesn't hurt, but it really isn't that important.
https://linustechtips.com/topic/859148-first-headphones/#findComment-10691806
Wired (no microphone)
A bit over the budget but this is a pretty solid pick for listening to music https://www.amazon.co.uk/Sennheiser-HD471G-Over-Ear-Headphone-Android-black/dp/B013UTN68U/ref=sr_1_11?s=electronics-accessories&ie=UTF8&qid=1510591086&sr=1-11&keywords=closed+headphones&refinements=p_n_style_browse-bin%3A1601095031#HLCXComparisonWidget_feature_div
A bit cheaper and looking at it I can tell of lesser build quality is the https://www.amazon.co.uk/Sennheiser-Closed-headphone-rotatable-earcup-Black/dp/B003LPTAZ2/ref=sr_1_1?s=electronics-accessories&ie=UTF8&qid=1510591194&sr=1-1&keywords=closed+headphones&refinements=p_n_style_browse-bin%3A1601095031
Wireless HeadSets (no microphone)
Comfortable, wireless, all around good headphones https://www.amazon.co.uk/Urbanears-Plattan-Wireless-Bluetooth-Headphones-Black/dp/B00XQ37XR6/ref=sr_1_3?ie=UTF8&qid=1510591290&sr=8-3&keywords=bluetooth+headphones+wireless
This is a solid popular choice, with a built in micrphone (though built ins tend to be trash and stop working often) https://www.amazon.co.uk/Mpow-Bluetooth-Headphones-Quanlity-Foldable-Black-Red/dp/B01N1KQGXZ/ref=sr_1_4?ie=UTF8&qid=1510591410&sr=8-4&keywords=bluetooth+headphones+wireless
Going into Headphones with a Micrphone
This Wired Headset was one of My First and a Favorite, but after I got the Logitech G930s I gave it to my younger sister. She uses it all the time with her Kindle so it works well with mobile devices. https://www.amazon.co.uk/Logitech-Gaming-Headset-Dolby-Surround/dp/B00CJ5FPUE/ref=sr_1_3?ie=UTF8&qid=1510591470&sr=8-3&keywords=gaming+headphones
This last one is one my roomate at college own. Its a great option, although its its bit more outta budget, but there are some very nice heaphones. https://www.amazon.co.uk/HyperX-Cloud-Gaming-Headset-Mobile/dp/B00SAYCXWG/ref=sr_1_4?ie=UTF8&qid=1510591593&sr=8-4&keywords=gaming+headphones
https://linustechtips.com/topic/859148-first-headphones/#findComment-10691862
10 minutes ago, RAM555789 said:
list
Unfortunately here (Italy btw) all those you listed me are way over budget. except for the cheaper ones, but I think there could be something better than those, and the Logitech wired one but I thought you meant integrated microphone like in the apple's in-ear, which is the one I have at the moment, gaming headset would be nice for indoor but aren't really that portable for outdoor usage. I guess I live in a crappy place for electronics.
Still, thanks a lot for your help! :)
https://linustechtips.com/topic/859148-first-headphones/#findComment-10691947
Yeah if you were in the UK only two of those would have been out of your budget.
https://linustechtips.com/topic/859148-first-headphones/#findComment-10692912
@RAM555789 @johnukguy Watching a bit of Z review I stumbled upon the Superlux 668b and they look really interesting, I would take the hm5 velour pads as he recommend too, do you have any experience with them?
Otherwise there are the 669 which are a bit more expansive but I'm willing to spend it if it's worth it.
https://linustechtips.com/topic/859148-first-headphones/#findComment-10722135
