Will supersampling help eliminate bottlenecking? (i5 4570 + GTX 1070)
1 hour ago, Nord said:IF what you are aiming for is a locked 60-70 FPS experiance, the CPU will (in most games) still do the trick.
just watch this for reference:
Your CPU is not on there, but I dont imagine it would be doing worse than an 2600k.
For the GPU a Titan X (maxwell) is just a bit weaker than a 1070, so this should be a somewhat reliable baseline for you.
Will your CPU hold you back sometimes, outside of engine limiations? Yes, it will.
But as long as you dont shoot for above 70FPS, you will not really notice it much.
Unless you really like CPU heavy games, like GTA5 or Tombraider, there I could imagine the CPU could be the cause of dips below 60FPS, sometimes.
You can always aim to OC the CPU - even if its not a K version, if you got a board that supports overclocking you can usualy even push even non-K CPU's to around 4 GHZ.
Alternatively higher clocked RAM, 1866mhz+ could increase FPS too.
But to also answer your question with supersampling and such, this will not effect the bottlnecking itself, it will just put "more stress" on the GPU, resulting in better quality but lower FPS.
Bottom line, I see no problem pairing this CPU with a 1070.
Just look at notebooks, they get 1070's & 1080's with CPU's that are just now around the "power" an overclocked desktop I7 2600 or 3770 would be and still do fine.
Awesome, thanks!
