Not enough fan headers on mobo
Solved by johndms,
8 minutes ago, OmriJ said:My mobo has one 4 pin CPU fan connector and one 3 pin "chasis fan" connector. I wanted to add 2 more case fans and I dont know how. Can I use this cable to split the cpu fan header safely without ruining anything/damaging the cpu? https://www.ebay.com/i/152637049666
if so, do the case fans have to be 4 pin or 3 pin works with 4 pin headers?
I have two of these - https://www.newegg.com/Product/Product.aspx?Item=N82E16812423163 - Each has three NZXT 140mm fans.
I've read somewhere not to exceed 1.0A per header, but perhaps the newer or better quality boards may be able to handle more. Those NZXT Fans use 0.14 A (0.30 A max.), so three of them max would be 0.9.
