You can either right click on the shortcut, select properties, go to the shortcut tab and change icon.
Or, you could try finding the main MS Word application, right clicking on it and creating a new shortcut and place it on the desktop, That may create a shortcut with the right icon.
https://linustechtips.com/topic/857763-how-to-fix/#findComment-10678118
I just cannot click on ''change icon'', it's in grey color., also when I'm looking for that program in start menu, the program there remain in inappropriate design as well.
https://linustechtips.com/topic/857763-how-to-fix/#findComment-10678944
2 hours ago, Tosa said:
Delete it, go find it in the start menu and drag&drop it back to the desktop.
I did it, but after that now I even could not find ms word in start menu, by the way, before detele the ms word, the design remained same in start menu as on desktop..
https://linustechtips.com/topic/857763-how-to-fix/#findComment-10679706
