FPS drops after few minutes
Solved it I think. I decided to update the bios to see if it fix my problem and it did. the struggle was real though and the mini heart attack when I tried to flash the bios then it just shut down and power went out. Luckily the bios update never did run when the power went out. Updated to latest bios, had issue when booting since it doesn't seam to pass A2 to boot hdd in POST. Then have to search older update before the latest one, flash it again hopping the power would stay, had another mini heart attack when it doesn't want to boot or got stuck in splash again and shuts down. decided to clear cmos, fire the bad boy up, booted, run GTA V and it didn't drop the FPS for no reason like it used to. Still drops in CPU intensive area but not like before. Fired up dota 2 played couple of hours without fps dropping below 60 even though CPU is at max load.
