So i want to build my own reliable gaming desktop so I can finally play games at high settings.
I have no experience in building PC's so this is a first.
Things u might want to know:
I'm not planning on overclocking
I'm from Belgium
It's mostly for gaming
Could u guys check this list out? Plz tell me if everything will work properly did i forget something, what needs to change and why,...
  1. MSI B350 TOMAHAWK, socket AM4 moederbord(RAID, Gb-LAN, Sound, ATX)
    https://www.alternate.be/PCs/Stel-je-eigen-PC-samen/PC-Builder#!/product//43/1335483
  2. AMD Ryzen 5 1600, 3,2 GHz (3,6 GHz Turbo Boost) socket AM4 processor(Wraith Spire cooler, Boxed)
    https://www.alternate.be/PCs/Stel-je-eigen-PC-samen/PC-Builder#!/product//44/1340580
  3. G.Skill 16 GB DDR4-3000 Kit, Werkgeheugen(Rood, F4-3000C15D-16GVR, Ripjaws V, XMP)
    https://www.alternate.be/PCs/Stel-je-eigen-PC-samen/PC-Builder#!/product//46/1218147
  4. ASUS GeForce GTX 1060 Strix Gaming 6G, Grafische kaart(DVI, 2x HDMI, 2x DisplayPort)
    https://www.alternate.be/PCs/Stel-je-eigen-PC-samen/PC-Builder#!/product//47/1286382
  5. Fractal Design Focus G, Tower-behuizing(Grijs, USB 3.0, Window-Kit)
    https://www.alternate.be/PCs/Stel-je-eigen-PC-samen/PC-Builder#!/product//49/1367110
  6. Corsair CX550M, 550 Watt voeding(Zwart, 2x PCIe)
    https://www.alternate.be/PCs/Stel-je-eigen-PC-samen/PC-Builder#!/product//50/1253695
  7. WD Blue, 250 GB SSD(M.2 2280, WDS250G2B0B)
    https://www.alternate.be/PCs/Stel-je-eigen-PC-samen/PC-Builder#!/product//69/1377903
  8. WD Blue, 1 TB Harde schijf(SATA 600, WD10EZEX, Bulk)
    https://www.alternate.be/PCs/Stel-je-eigen-PC-samen/PC-Builder#!/product//71/1013040
  9. Trust Avora 2.1 Subwoofer Speaker set, PC-luidspreker(Zwart)
    https://www.alternate.be/PCs/Stel-je-eigen-PC-samen/PC-Builder#!/product//79/1262875
  10. LG 29UM59-P, 29" UltraWide Monitor
    https://www.alternate.be/PCs/Stel-je-eigen-PC-samen/PC-Builder#!/product//89/1356675
  11. Microsoft Windows 10 Home 64bit, Software(Nederlands)
    https://www.alternate.be/PCs/Stel-je-eigen-PC-samen/PC-Builder#!/product//130/1213101
https://linustechtips.com/topic/857184-rate-my-first-build/
You need to overclock the 1600 right off the bat. The stock 3.2GHz clock is awful.
CPU: AMD Ryzen 5 1600 3.95GHz [1.365v] // Mobo: ASRock B350 Pro4 // GPU: EVGA GTX1070 8GB SC Black Edition
Case: NZXT S340 Elite // Cooler: NZXT Kraken X62 // RAM: Corsair Vengeance RGB 16GB 3066MHz // Misc: NZXT Hue+
Storage: WD Green 120GB M.2, SK HyniX 250GB SSD, Samsung Evo 250GB SSD, Seagate 3TB 7200RPM // PSU: Corsair RM750X
CPU-Z Validation // Userbenchmark // PC Part Picker
https://linustechtips.com/topic/857184-rate-my-first-build/#findComment-10672161
You don't need 16 GB RAM for gaming.
ORANGE SCREEN WINDOWS 10 VALUE OVER TIME - PC VS MAC
i5 7600k @ 5.0 GHz xD
Corsair H60 with Noctua NF-F12 iPPC-3000 PWM
MSI Z270-A Pro Motherboard
EVGA 1050 Ti SC
16 GB Corsair DDR4 @ 2400 MHz
500 GB Sandisk 950 PRO - Windows 10, Elementary OS, Zorin OS
500 GB Sandisk 850 PRO
1 TB WD Blue
Corsair CX750
1 x Corsair AF120 Quiet Red Led
Rosewell Tyrfing Case
EliteBook 8570w
i7 3720QM @ 2.6 GHz
Quadro K1000M
24 GB DDR3 @ 1600 MHz
250 GB SanDisk 850 EVO - Elementary OS, Windows 10, Debian
i5 3470 @ 3.2 GHz
EVGA 750 Ti SC
8 GB DDR3 @ 1333 MHz
240 GB SanDisk - Windows 10, Linux Mint
https://linustechtips.com/topic/857184-rate-my-first-build/#findComment-10672162
I'm from Belgium
Get a 1080 instead; maybe even 1080 ti. Intel is better, so get an i5. Guys will i5 bottleneck 1080 ti?
https://linustechtips.com/topic/857184-rate-my-first-build/#findComment-10672165
Ideally 16GB is optimal...
https://linustechtips.com/topic/857184-rate-my-first-build/#findComment-10672168
For gaming at 1080p? No. You only need 8 GB for gaming only.
EVGA 1050 Ti SC
1 TB WD Blue
Corsair CX750
EliteBook 8570w
i7 3720QM @ 2.6 GHz
Quadro K1000M
i5 3470 @ 3.2 GHz
EVGA 750 Ti SC
https://linustechtips.com/topic/857184-rate-my-first-build/#findComment-10672176
2 minutes ago, CyberFern0 said:
troll?
No. I don't know why you find this funny. 8 GB of RAM is all that is needed for gaming in 2017 at 1080p.
EVGA 1050 Ti SC
1 TB WD Blue
Corsair CX750
EliteBook 8570w
i7 3720QM @ 2.6 GHz
Quadro K1000M
i5 3470 @ 3.2 GHz
EVGA 750 Ti SC
https://linustechtips.com/topic/857184-rate-my-first-build/#findComment-10672177
Don't listen to this guy . . .
EVGA 1050 Ti SC
1 TB WD Blue
Corsair CX750
EliteBook 8570w
i7 3720QM @ 2.6 GHz
Quadro K1000M
i5 3470 @ 3.2 GHz
EVGA 750 Ti SC
https://linustechtips.com/topic/857184-rate-my-first-build/#findComment-10672183
Just now, CyberFern0 said:
FOr minecraft and roblox maB
Dude. You got problems.
EVGA 1050 Ti SC
1 TB WD Blue
Corsair CX750
EliteBook 8570w
i7 3720QM @ 2.6 GHz
Quadro K1000M
i5 3470 @ 3.2 GHz
EVGA 750 Ti SC
https://linustechtips.com/topic/857184-rate-my-first-build/#findComment-10672190
Look at this image of my current RAM usage. All I'm using is Chrome. You're telling me 3.69GB's of RAM is enough to run games released in 2017?
https://linustechtips.com/topic/857184-rate-my-first-build/#findComment-10672196
IMO, your gaming experience would be much better if you cut the ram to 8gb, went with the 3gb version of the 1060, and invested those dollars into a good speaker system instead of a cheap one.  you'd only lose 5-10 frames but you'd gain a much more immersive experience
PC Build: R5-1600.  Scythe Mugen 5.  GTX 1060.  120 GB SSD.  1 TB HDD.  FDD Mini C.  8 GB RAM (3000 MHz).  Be Quiet Pure Wings 2.  Capstone-550.  Deepcool 350 RGB.
Peripherals: Qisan Magicforce (80%) w/ Gateron Blues.  Razer Naga Chroma.  Lenovo 24" 1440p IPS.  PS4 Controller.
Audio: Focusrite (Solo, 2nd), SM57, Triton Fethead, AKG c214, Sennheiser HD598's, ATH-M50x, AKG K240, Novation Launchkey
Wishlist: MP S-87, iPad, Yamaha HS5's, more storage
https://linustechtips.com/topic/857184-rate-my-first-build/#findComment-10672199
1 minute ago, minervx said:
gaming doesn't really need more than 8gb of ram.  (if you do need 16, you can always upgrade, but dont waste the money)
gtx 1060 6gb is a good card, but 3gb is a much better value for your dollar and the 6gb version is only slightly better
buy a better speaker system.
There's more than just memory differences between the 3GB 1060 and 6GB model...
https://linustechtips.com/topic/857184-rate-my-first-build/#findComment-10672207
Yes. I am.
EVGA 1050 Ti SC
1 TB WD Blue
Corsair CX750
EliteBook 8570w
i7 3720QM @ 2.6 GHz
Quadro K1000M
i5 3470 @ 3.2 GHz
EVGA 750 Ti SC
https://linustechtips.com/topic/857184-rate-my-first-build/#findComment-10672208
yes but they're not consequential for the asking price.
https://linustechtips.com/topic/857184-rate-my-first-build/#findComment-10672211
Yes. I am.
Usage and budget should be a key factor, as Greg openly states. Let's say OP wanted to play CODWII whilst listening to a YouTube video or music through iTunes, 8GB will not cut it.
https://linustechtips.com/topic/857184-rate-my-first-build/#findComment-10672224
The prices of the 6GB model (depending on the vendor) is roughly £40, that's a fairly small price to pay for additional CUDA cores and double memory.
https://linustechtips.com/topic/857184-rate-my-first-build/#findComment-10672228
double memory sounds like alot, but for heavy 1080p gaming and light 1440p gaming (which is what the card is for), 3gb memory is perfectly fine.
tests ive seen have shown like a 1-5 frame improvement at most usually.  meh
https://linustechtips.com/topic/857184-rate-my-first-build/#findComment-10672230
He would be much better off going with a 1070 with 8 GB of RAM. I ran 8 GB for quite a few years. It can handle multitasking very well. Never once did I go over 6 GB used even while watching YT, gaming and listening to music at the same time.
EVGA 1050 Ti SC
1 TB WD Blue
Corsair CX750
EliteBook 8570w
i7 3720QM @ 2.6 GHz
Quadro K1000M
i5 3470 @ 3.2 GHz
EVGA 750 Ti SC
https://linustechtips.com/topic/857184-rate-my-first-build/#findComment-10672235
8 gb is plenty but if he's going to something like a 1080 or higher like some people are saying then 16 is good
Retrowave
Air cooled version of my first PC.
CPU: Intel Core i7-8700K
Cooler: Corsair H150i PRO
Thermal Compound: Thermal Grizzly Kryonaut Thermal Paste
Motherboard: Asus ROG MAXIMUS X HERO (WI-FI AC)
RAM: G.Skill Trident Z RGB 32GB (4 x 8GB) DDR4-3600 Memory
SSD: Samsung 960 Pro 512Gb M.2-2280 Solid State Drive
SSD 2: Samsung 970 EVO Plus 1TB M.2-2280 Solid State Drive
HDD: WD Black 6TB 3.5" 7200RPM Internal Hard Drive
HDD 2: Seagate Barracuda PRO 4TB 3.5" 7200RPM Internal Hard Drive
GPU: EVGA GeForce GTX 1080 Ti FTW3
Case: LIAN LI O11 Dynamic XL
PSU: EVGA SuperNOVA P2 1000W 80+ Platinum Fully-Modular ATX Power Supply
Case Fans: Corsair LL120
Fan Controller: Corsair Commander Pro
Set Up
  • Mouse: Razer Deathadder Elite
  • Keyboard: Razer Blackwidow X Chroma
  • Mousepad: Steelseries QcK Gaming Mousepad
  • Monitor: Asus ROG Swift PG278QR
  • Audio
    • AMP: Sennheiser GSX1000
    • Headphones: Sennheiser 58X
    • Speakers: Bose Companion 2 Series III
  • Oculus Rift + Touch 3 Sensor Roomscale Setup
https://linustechtips.com/topic/857184-rate-my-first-build/#findComment-10672242
very true, they really don't know their stuff
Retrowave
Set Up
  • Audio
https://linustechtips.com/topic/857184-rate-my-first-build/#findComment-10672247
I'm gonna be honest i dont know the differences between what u guys are discussing... As i said i've never done this before and i dont know much about all the different parts... Generally i'm want to play games with good graphics.
So my biggest worry was if the list was compatible with each other, but that is not a problem if i read your responses.
The main issue is the 8GB vs the 16GB right? I dont know the difference to be honest... So what to choose and why?
Overall tho, looking at this list. Would all this work?
https://linustechtips.com/topic/857184-rate-my-first-build/#findComment-10672266
Again, just like art, it's subjective and relative. In this case, the correct answer would be OP's intended usage. The reason why I suggested (and personally chose) 16GB as apposed to 8GB, was my intended usage. Gaming, graphics work, video editing and audio production as well as knowing there's always more RAM on tap so I'm never left with hardware limitations.
https://linustechtips.com/topic/857184-rate-my-first-build/#findComment-10672271
 The best way to decide is what is your budget? Also I think 8Gb is definetley good enough for something like a 1060
Retrowave
Set Up
  • Audio
https://linustechtips.com/topic/857184-rate-my-first-build/#findComment-10672273
